Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 04-10-2008, 02:42 PM
mcjones22 is on a distinguished road
Feed rates for a JGRO
I've recently completed a JGRO router table. At present my maximum feed rate is a modest 100 mm/min with a maximum cutting depth of 1 mm for MDF. My motors and electronics are capable of higher speeds however the machine is unable to cope with these high speeds.
I was wondering what other builders have experienced and what can be done to optimise the feedrate.
Old 04-10-2008, 04:36 PM
silentreaper is on a distinguished road
What did you use for your threads, did you use a standard all thread or did you use an acme thread with multi starts?
I initially built my Jgro table with the suggested 1/4-20 all thread and was seriously limited as to how fast I could cut, I have since upgraded to acme 1/2-8 2 start and have easily doubled my capable cutting rate now mind you I never spent a lot of time fine tuning the machine either so you results may vary.
Old 04-12-2008, 01:46 PM
NB70 is on a distinguished road
What are the exact problems? Do the motors stall or lose steps? Or is the machine flexing at high speeds?
Feed rates? Rainman229 G-Code Programing 3 02-23-2007 11:47 AM
Feed rates & IPM ChristopherWood WoodWorking 6 10-30-2006 03:08 PM
Feed Rates rcheli Benchtop Machines 0 12-28-2005 10:34 AM
Router bit feed rates. ynneb DIY-CNC Router Table Machines 3 05-28-2004 11:54 AM
Rpm and Feed Rates Xeno General CAM Discussion 35 02-23-2004 04:06 PM
