Page 5 of 5 FirstFirst ... 2345
Results 49 to 53 of 53
Thread: JGRO in basement (upstate NY)
  1. #49
    Gold Member jgro's Avatar
    Jul 2003
    Since you are using Inkscape to make your drawings, try using PartKAM to make your gcode. I found it to works much easier. https://launchpad.net/partkam
    Attached Thumbnails Attached Thumbnails JGRO in basement (upstate NY)-screenhunter_01_nov._22_15.03.jpg
    http://jgroshoppages.blogspot.com/
  2. #50
    Oct 2007
    partkam
    Thanks JGRO, I will give it a try.
    ElSeed
  3. #51
    Oct 2007
    Problem with PartKAM
    When I load in my inkscape svg file it gets scaled by some amount. I didn't find this out until after I cut my block . But it was a test cut for just this sort of reason and the machine didn't run into anything.
    Any ideas on why this happens? I attached the svg file for anyone to do what they will with. I drew it in Inskcape. I renamed it .txt so it would upload. Rename back to .svg and it should work for anyone who wants to play around.
    But I liked PartKAM more than the Inkscape tools.
    Quote Originally Posted by jgro View Post
    Attached Thumbnails Attached Thumbnails JGRO in basement (upstate NY)-largeadjustmentblock.png   JGRO in basement (upstate NY)-largeadjustmentblock_inkscape.png
    Attached Files Attached Files
    ElSeed
  4. #52
    Jul 2003
    I didn't download the file, but I think I know what the problem is. In PartKam you need to go under edit/edit preferences and change the SVG Import Value to 90. You have to do this every time you start PartKam since it doesn't save any preferences when you exit. This should scale everything properly.
    jgro
    Attached Thumbnails Attached Thumbnails JGRO in basement (upstate NY)-screenhunter_01_dec._06_06.30.jpg
  • #53
    Oct 2007
    jgro
    yup, that was it. Thanks JGRO! I will make the machine upgrade itself soon hopefully.
    elseed
    ElSeed
  • Page 5 of 5 FirstFirst ... 2345
    1. VMC in basement?
      By XXF in forum Haas Mills
      Last Post: 02-15-2012, 08:54 AM
    2. UPSTATE New York/Penn.....? MACH III cnc'ers
      By kmcwhq in forum Mentors & Apprentice Locator
      Last Post: 10-18-2008, 11:05 PM
    3. Bobcat in the basement
      By metalbyter in forum CNCzone Club House
      Last Post: 02-28-2008, 02:32 PM
    4. Mentor in Upstate NY, Capitol District???
      By victorf in forum Mentors & Apprentice Locator
      Last Post: 12-16-2006, 05:54 PM
    5. Basement Workshop
      By Hack in forum CNCzone Club House
      Last Post: 01-13-2006, 09:26 AM
