| JGRO Router Table Design For the discussion of JGRO designed router table. |
JGRO is up and running... well almost. I have all the motors jogging now, but one of my axis (x-axis) doesn't seem to like the initial movement after it has gone into sleep mode when not being used for 10 seconds. When I press the right arrow on the keypad initially or use jogging commands, the motor makes a humming noise but doesn't rotate. If I just tap the jog or right arrow once to "wake up" the motor, I can then move the axis with no issue. As soon as I let the motor sit with no movement for ten seconds and then go to hold down the movement command, it just makes noise. Also, what should I set the motor steps per inch, acceleration in/sec/sec, and velocity in/per min at for my 305 oz motors and hobby cnc pro driver board? All installed on a JGRO. I'm past the build so this is the fun part, but very crucial to setting up the table for cutting operations! Thanks! Matt |
| Matt |
| what is to "slave" a stepper motor? | salvaCNC | Stepper Motors and Drives | 10 | 12-03-2007 03:41 PM |
| Help finding information on Sanyo Denki "Step Syn" IBM stepper motor | Oracle_9 | Stepper Motors and Drives | 12 | 06-08-2007 12:55 PM |
| Boss 6 Motor Pulley Options - 5/8" to 1/2" Bore | snakebit95 | Bridgeport and Hardinge Mills | 0 | 08-11-2006 02:03 PM |
| another "which motor and controlller" thread | cowanrg | Stepper Motors and Drives | 17 | 06-20-2005 03:10 AM |
| How do you "connect" dual motor X axis ? | Calico | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 03-17-2005 01:28 PM |
