Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 12-24-2007, 01:23 PM
newtometal is on a distinguished road
Going to be starting a jgro, so here comes the questions
Well as the title says, i'm planning to start a jgro after the holidays, and of course i have a few questions. I've searched the forum but was unable to come up with the answer for these two questions.
1. On the jgro thread the question " on your website you mentioned some flex in your router.. was that in this version, or an older version..? " was asked and answered with " My first design had a lot of flex. I first tried using 3/4" black pipe. It didn't work. That's when I went to 1 1/2" pipe ". In the plans i have it calls for 1 inch gas pipe and half inch gas pipe. So i guess my question is do i have the most up to date plans?, And what diameter pipe hase everyone else been going with?
2. If i plan on trying to make a joes model at some point, what would be the size adjustment needed to the jgro so the jgro would be able to make the cuts? Is it just a matter of length of the Y diemension?
Well that's alll the questions for now, i'm sure there will be more. Thanks for the help.
Old 12-24-2007, 01:35 PM
ger21's Avatar
Not sure about #1, but it will still have some flex no matter what size it is, and for #2, if you make it bigger, it will flex even more.
a million questions about starting cnc Data General Metal Working Machines 28 04-14-2008 11:49 AM
JGRO questions randyf1965 JGRO Router Table Design 13 01-18-2007 08:29 PM
starting small. have a few questions ejholmgren DIY-CNC Router Table Machines 10 09-23-2006 08:09 AM
Newb here, just a few starting off questions.. SlimJimmy CNC Plasma and Waterjet Machines 9 04-27-2006 11:56 AM
Questions for starting and a formula ... elenabux General Metal Working Machines 3 07-17-2004 06:54 AM
