Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 06-10-2007, 12:24 PM
sjblair4 is on a distinguished road
Where is Dtl26 used?
I've scoured the JGRO plans and cannot figure out where Item cnc_dtl26, .50" x .52" aluminum, is used. Can anyone help me with this please?
Old 06-10-2007, 06:46 PM
edo edo is offline
edo is on a distinguished road
It's a spacer that goes on the bolts between the bearings and the aluminum angle on the Y Linear Guide Assembly. It's called out in assy08. I didn't use it, and as others have also done, just put two nuts on the bolts as a spacer.
I just noticed this is your first post. Welcome and good luck with the build.
Ed
Last edited by edo; 06-10-2007 at 06:54 PM. Reason: Just noticed it was your first post
