| JGRO Router Table Design For the discussion of JGRO designed router table. |
OK – now it’s my turn for a new JGRO build. I’ve been lurking/reading for months on this site, and have ordered (and received) the 305 oz/in 3-axis package kit from HobbyCnc. Soldering __should__ commence this weekend… I’m at the point where I have to commit to some of the details, so I’d like some advise: CONSTRUCTION: I have some ¾ in birch plywood left over from a recent job, and am wondering if this would be superior to ¾ in MDF? While the dimensional stability of any hardwood probably would not be as good as the MDF, I would think that the plywood would be Nearly the same as MDF. There would certainly be less “tear-outs” from tapped holes etc. Opinions??? GLUE: I’ve read that some builders do/don’t use glue on their builds – I’m thinking of Gluing the base, and possibly some of the Z-axis frame. Any recommendations for or against? Also, I’ve read somewhere (???) about a certain type of tap that should be used when tapping MDF. I can’t find the link again. As I remember, it does a better job with composites like MDF – any suggestions? LEADSCREWS: From reading other posts from JGRO builders, I’m certainly not going to use the ¼ - 20 threaded rod - But the question is: If I use ½ - 10 Acme 1-start ($6.99 for a 6 foot length from ENCO), can I later substitute it for ½ -8 Acme 2-start from McMaster Carr or MSCdirect? (about $45 - $60 for a 6 foot length!!). I would imaging that the bearings and LoveJoy couplers could be re-used. [So – why is there such a huge difference between ENCO and MSC (even for the same ½-10 1 start rod - about $25 from MSC vs. $7 from ENCO. Is the ENCO rod of similar quality ??? Will the ENCO ½-10 Acme 1-start rod get me started for a while???] I figure that from the RPM vs Torque graphs, I can/should run the motors at a max of 400 RPM before the torque significantly rolls off (or they start to whip) – this should get me about 40 inches per minute using the Excel spreadsheet from the FAQ section??? COUPLERS:I’d like some advise about the LoveJoy couplers vs the DumpsterCNC ACME couplers. As I see it, the Lovejoys are half the price, and can be re-used if I upgrade to ½-8 Acme 2-start rods. I’d have to purchase a different set of couplers if I went for the DumpsterCNC type. I’m also assuming that the LoveJoy couplers only need you to possibly make a flat spot on the Acme rod – no keyway needed to machine, and the rod does not have to be turned down. I also think that the loveJoys would be more forgiving to mis-alignment of the rod to the motor – I would think that a direct coupling could result in forces on the motor bearings that they were not designed for. For the reasons just mentioned, I’m leaning towards the LoveJoys – but are they good enough? Do they exhibit much “slop”? SIZE: I’ve read that the usable table size of the JGRO is about: > Jgro: The cutting area is about 30" x 15" x 6". And that some of the pieces of the Joe2006 are too large to make on this table. >Some of Joe's part measurements that are longer than the JRGO can cut: >Router end supports 33.95"~ >Torsion box bottom 34.5"~ >Gantry sides 30"~ >Torsion box long braces 41.36"~ From reading this site, it seems *everyone* makes a second, third… machine! So… If I expand the JGRO to have a usable table size of about 42” x 20” x 6” , and use the rail stabilizing technique that I’ve seen on this board (reddish/orange pipe supports – possibly from GliderGider’s build), would I be satisfied with the result, or would I only get aggravation ? [Note that I’m planning on adding that mod to the basic JGRO once it is up and running anyway]. Like they say, “size isn’t everything”… should I stick with the basic JGRO footprint to start out with? 4TH AXIS: My long term plans are to build up a 4th axis, But I’d probably start with a manual indexing jig – so that I can accurately flip a piece of work over to rout the bottom. From all of my reading etc., I haven’t seen a JGRO or Joe2006 with any type of 4th Axis – anyone using one? (or have a link to a “real cheap” method of doing this?) INSTRUCTIONS:Is there a set of written text instructions (similar to what Joe did for the Joe2006), for the JGRO? If not, they are obviously not needed, based on the number of JGRO’s I see out there - but a text writeup with some hard learned assembly/alignment tips would be nice… [note that I’ve gone through most, if not all of the JGRO build threads, and have squirreled away all the tips that I’ve seen] SOFTWARE: Well – that’s a whole other set of questions… Thanks, Don Last edited by dbprojects; 06-08-2007 at 02:00 PM. Reason: Spelling |
The tap is a roll form. Thats what we call them, the tap acutally "forms" the material into threads as apposed to cutting which is what you can get when you buy a tap at any hardware store. Another thing to know about roll form taps is you need to drop you drill size a bit. When I used to work at "terrible machine shop/assembly facility.IND" we cut aluminum almost exclusively, and we used roll form taps almost exclusively, it was rare to use a cutting tap at all, then again we weren't a prototype/short run facility either we ran high volume orders.
http://www.cnczone.com/forums/attach...7&d=1177635932
http://www.cnczone.com/forums/attachment.php?attachmentid=33325&d=1173572303 here's his thread: http://www.cnczone.com/forums/showth...light=lionclaw good luck. edit: Sorry about the "bold" can't seem to get it all taken out |
| Looks like great advice from Jordan and the SilentReaper. So I won't add anymore duplicate advice. Here's my limited comment. Don't tap all the threads that plans call out. Drill and pilot for a wood screws. Use all the suggested bolt locations, but use long phillips head (trumpet head) wood screws. It's so much faster and just as strong. Glue most all the joints with carpenters glue. Some joints I didn't glue, so I'd have access later. Table top is one of those joints. Your reference to my stabilization method is a misquote. My table is standard length and I didn't stablize the X axis. I forgot who did that, but I know what you're talking about. Good luck with your build. If your skills with computer CAD is pretty good, then I'd recommend that you build the Joe's2006R2 rather then the JGRO. If you are like me (I wanted a paper drawing) then go with the JGRO. |
| SilentReaper, Thanks for the inputs. I'll look around to see where I can get the correct "roll form" tap. So, if you only bought 1 acme coupler from DumpsterCnc, did you use LoveJoys for the other 2 axis? Thanks again, Don |
| Tajord, Very, very nice build! You said that your cutting area (x) is 46". Did you keep the other axis as they were (y=15, z=6)? I realy like the enclosed base - it must cut down on the sawdust getting everywhere. Also, thanks for the 4th axis link. It's something to think about for the future... Don Last edited by dbprojects; 06-12-2007 at 04:22 PM. |
By the way - what do you guys do with your 1st / 2cnd / 3rd machines??? Thanks, Don |
| I had no idea how much enjoyment I'd have with this hobby. At this point, if I could have done it again, I'd build a Joe2006. Mostly for the extra inches. I'm not even sure how much bigger they are, but I want a bigger table now. I'm also a lot braver now after working in this hobby for 6 months. Plus, I would give me an excuse to buy a band saw to help cut out those complicated parts. Never mind that I said all this. I'm having a GREAT time with my JGRO. The other thing to avoid glueing are the aluminum angles that hold the bearings. You may need to shim that and if you, well, it will limit your adjustment. |
good luck. |
#10
| Reaper Edit: and as far as the roll form taps, a quick look at MSC the cheapest 1/4-20 they have is $9.61 but they do have them, apparently they are really called "thread forming" taps, well I guess thats what you get when you work at a place that uses there own lingo long enough. |
#11
| What are your experiences with the LoveJoys? Is there very much slop? Don |
#12
| Reaper |
| My turn at a Jgro build | silentreaper | JGRO Router Table Design | 31 | 06-17-2007 12:14 AM |
| SeniorCNC (JGRO Build) | me85638251 | JGRO Router Table Design | 25 | 04-21-2007 10:46 PM |
| A JGRO Rev 2 build without CNC assist | BMG | CNC Wood Router Project Log | 3 | 03-19-2007 12:21 PM |
| going to build the jgro | clammy23 | DIY-CNC Router Table Machines | 0 | 01-04-2007 05:44 AM |
| Yet another jgro build | bnoble | JGRO Router Table Design | 2 | 11-16-2005 09:51 PM |
