| JGRO Router Table Design For the discussion of JGRO designed router table. |
#50
| Well nearly finished the aluminium machine - so will use it to make the jrgo that I started on earlier in this thread - It seems a real shame not to finished what I started
__________________ Drakkn Guitars http://www.uk-guitarshop.co.uk |
#51
| Hi just coming in on this thread after reading all the posts before. I was lucky enough to be given a jgro by a kind hearted sole on this forum. Just needing all the electrics, I bought and installed a 3 Nm 48v system bought from Motion Control. The one thing I was told by the person who donated the machine (which I had to deal with) and read of others having the same problem is the spread of the unsupported rails. This is a real issue with the gas pipe design and if I would change anything I would definitely use a different rail system. Some have braced across the table with long studding and packed against the sides. Using the packing blocks that came with my table, I have finally got over it by screwing one side to a wall and introducing a 2" x 2" length of angle iron down the outside edge of the other side. Only up and running 3 days ago I would strongly recommend anyone about to use Mach 3 to watch the training videos on the Artsoft site. Oddly although mentioned that the demo version allows 1000 lines of code, I think that was with Mach 2 as my Mach 3 demo only allows 500 lines. The problem solving video shows how to calibrate your table, something I would have thought should have been in the setup video, although dead easy, make sure you watch both, it could have saved me a day of head banging ![]() Still not cutting yet but hope to be real soon. Also in West London (Uxbridge, Harrow area) |
#52
Thanks for the info about the videos - I have downloaded as much stuff as I can from the mach website - and will have a good watch before playing with the machine which is near completion.However may not be able to work on it for a while as moving house is in the pipeline.Once settled in the new place will strive to get my maching up and running and earning money for itself.
#53
| Well I am back, Moved house settled in, put machine back together , ran it up, now at the stage where my son and i have (we think) go the accuracy sorted out , just need to test some shapes , loaded up the road runner from mach 3 - but I believe its dimensions are in imperial and I use metric so thats no good.Anyway willl do some more testing in the morning.
#54
| Got hold of the g code for the kress mounting - loaded into mach3 and did a test run using mdf - Have a slight accuracy problem - the router mounting is made from hdpe which appears to be flexing so not producing accurate dimensions.So will now make a mounting from aluminium when I can find some. Also need a good way of holding down the work piece - probably go woth double sided tape to start with. Hey nearly there though - just trying to find a cad package now that is relatively easy and cheap to use. Any ideas - autocad is way too complicated for me.
#55
| Ok I finally have something to show for all my efforts and all your help on the zone. Anyway still have some problems with flexing from the z axis which is causing dimensional problems but pleased with things so far. More things to overcome - how to hold the work down - double sided tape ? or build a vacuum bed ? Oh yes and learn mach3 and turbocad comments gratefully received.
#56
| Hold Down... Only one way. Buy 4 of these units. You won't be disappointed. Get one of these. http://www.rockler.com/product.cfm?page=5209&cs=1 Get three of these http://www.rockler.com/product.cfm?page=5325&cs=1 (item 21753) Believe it or not, both of these products go on sale for half price. So wait on the sale. |
| JRGO Cut List | tonybert | JGRO Router Table Design | 7 | 06-05-2009 09:52 PM |
| JRGO Plans in metric | Drakkn | JGRO Router Table Design | 6 | 01-23-2007 11:10 AM |
| Hyudai starts in metric | Jedi | General Metal Working Machines | 0 | 10-17-2006 07:23 PM |
| Starts | AZCoyote | CNC Plasma and Waterjet Machines | 12 | 01-20-2005 05:33 PM |
