Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
  #37   Ban this user!
Old 03-23-2007, 10:45 AM
voltsandbolts's Avatar
voltsandbolts is on a distinguished road
SSR Box
Shocking!
Ok, this is the info that Tjord and Dan dimock asked about in Tjords thread, I thought I would post it hear too. I recommend you do a little research on the net to find the right SSR for your needs. Use the info at your own risk. If you aren’t electrically inclined find someone who is….Please.
Deeds not words...
VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/
  #38   Ban this user!
Old 03-24-2007, 12:21 PM
Test Cuts.
Now that I have worked out most of the backlash and lost step issues, It’s time to cut something. I drew up a mounting plate to fit a #23 motor and ran it. Here are a few pics of the setup, cutting and the part. The part came out good. And fit the boss on the motor perfectly.
The part was made with, Acad, Ace, TurboCNC.
I made some video clips but they are huge.
ID:	34167   Click image for larger version
ID:	34168   Click image for larger version
ID:	34169   Click image for larger version
Deeds not words...
  #39   Ban this user!
Old 03-24-2007, 12:59 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
Thumbs up
Very cool, I really like your build. FWIW, Im using Mach3 and V-Carve Pro.
So are you going to thread your anti-backlash nuts for your screw yourself?...How is this done for flat threads as on ACME/BallScrews, is there an off-the-shelf tap, or do you need a cnc lathe?
  #40   Ban this user!
Old 03-24-2007, 10:36 PM
Glidergider is on a distinguished road
Hi V&B,
Great test parts. That's great and the perfect fit is icing on the cake. Thanks for the pics.
Dave
  #41   Ban this user!
Old 03-25-2007, 08:24 AM
Thkoutsidthebox,
Yes I believe you can buy an Acme thread tap, but I think a lot of guys make one from a cutoff of the lead screw.
Deeds not words...
  #42   Ban this user!
Old 03-26-2007, 06:14 PM
Last night and this evening I cut the mounts for the router I am going to use. There glued up and clamped, and I took off the Dremel I have been using. Hopefully in the next day or two I’ll get the router mounted up and do some test cuts. Plus post a few more picks.
Deeds not words...
  #43   Ban this user!
Old 03-26-2007, 08:41 PM
ACME Tap
Here's a photo of my ACME Tap.
http://flickr.com/photos/41267292@N0...7594505361068/
  #44   Ban this user!
Old 03-27-2007, 04:15 PM
I finally had a free minuet to post the photos of the router mount.
Here it is…
ID:	34356   Click image for larger version
Deeds not words...
  #45   Ban this user!
Old 03-27-2007, 05:14 PM
Don't ya just love that CNC? Good looking parts.
  #46   Ban this user!
Old 03-27-2007, 07:21 PM
Tonight I had an hour to spend in the shop and got the router mounted. It took 32min to cut each clamp (remember I was cutting with a Dremel, can you say “multi pass”). I am also going to try a cheap-O speed controller from Harbor Freight. So for now the Dremel is off and the router is on. Now I need to redo my drawings with a new offset for a ¼” cutter.
ID:	34363   Click image for larger version
ID:	34364   Click image for larger version
Deeds not words...
  #47   Ban this user!
Old 03-27-2007, 11:40 PM
That's really looking good. You are going to love the stronger router. Multi-multi-pass days are gone. Now it's a couple-o-pass ahead.
  #48   Ban this user!
Old 03-28-2007, 04:27 AM
tajord is on a distinguished road
Looking good there VB, all this tweaking and modifying you guys are doing, I just can't wait to get mine done, little envious here j/k about the kicking knee thing, let us know how the new router's working out for yuh.
A JGRO Rev 2 build without CNC assist BMG CNC Wood Router Project Log 3 03-19-2007 12:21 PM
going to build the jgro clammy23 DIY-CNC Router Table Machines 0 01-04-2007 05:44 AM
JGRO Build - Some Assembly Required HayTay JGRO Router Table Design 5 04-04-2006 09:03 PM
Yet another jgro build bnoble JGRO Router Table Design 2 11-16-2005 09:51 PM
jgro Style CNC Build Journal ignatz JGRO Router Table Design 48 09-22-2005 08:03 PM
