Results 1 to 4 of 4
Thread: Help with plan nomenclature
    Dec 2006
    Before I drill the holes into all this freshly cut wood I need a clarification on the the plans.
    I am working on the Large Adjustment Block:
    What is meant by 13/64" Thru All? and,
    0.201 Thru 1/4-20 UNC - 2B x 0.510" ?
    Which one is to be tapped and which one is to be drilled thru with no tapping?
    Any help would be most.....helpful.
    Thanks ahead of time, this is a wonderful site. Thanks again
    edo
    edo is offline
    Oct 2006
    Northern VA
    Thru means drill all the way through the material, the "All" I believe means for 'all' holes that are marked with the same symbol.
    "0.201 Thru 1/4-20 UNC - 2B x 0.510" tells you to drill a .201" hole all the way 'Thru' and tap it for 1/4-20 UNC. I'm not sure what the 2B means, but the .510" is the depth of the thread. You don't have to be exact here, just thread enough for the bolt that you're using - too much thread won't hurt.
    A 1/4"-20NC tap is for 1/4" bolts with 20 Threads per Inch (TPI). Unless you have a set of numbered drill bits (#7 = .201) you can use a 13/64" bit for these holes too.
    Dec 2006
    I thought that was how it worked but wanted to be perfectly sure.
    Thanks EDO, I knew if I asked it would be answered here on this forum.
    Dec 2006
    edo,
    I can clarify the "2B". That's a Class of thread. Image a machine shop building a close tolerance engine block and head assembly. This type of assembly would specify a Class 3B thread. Basically, class three is a precision thread while a class 2b is a medium precision version. Class 1B is seldom used in my circle of life.
    Dave
