Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 01-09-2007, 10:30 AM
EMCLLC is on a distinguished road
new guy in need of parts help
I am looking to order most of the parts first so I can see how they go together before i cut the wood.. I was wondering about part numbers for the bearing flanges.. what size and all that fun stuff.. I was looking on mcmaster.com for those as per jgro.
Also I was reading somewhere in here about using galvinized pipe instead on black because it is smoother... but is it as strong? any thoughts?
Old 01-09-2007, 11:18 AM
Jason Marsha is on a distinguished road
Black pipe is better. Galvanised pipe is rough.
If both are sanded, black pipe is still smoother.
Jason
Old 01-09-2007, 11:27 AM
what about the flange bearings? I am planning on using this kit
http://www.kelinginc.net/ThreeAxisPackage425.pdf
Old 01-15-2007, 01:28 AM
edo edo is offline
edo is on a distinguished road
I posted to your other post about embedding 1/2" bearings instead of flange bearings, but if you're using 1/4" rod the flange bearing I bought from McMaster Carr, the one in JGRO plans, is part number 6383K213 "Steel Ball Bearing Flanged Open for 1/4" Shaft Dia, 11/16" Od, 5/16" W In stock at $2.79 Each"
