Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 11-30-2006, 01:19 AM
farr_t is on a distinguished road
Question having problems adjusting y axis
im having problems getting all the bearings to roll on the y axis.
is there a good method to allign the y axis pipes.
thanks for the help
Old 12-01-2006, 10:30 PM
Jason Marsha is on a distinguished road
When I built my JGRO I had the same problem. My solution was very low tech and a bit clumsy but it works. As long as the bearing is not too far from the pipe, loosen the bolt that holds the angle aluminium to the mdf and put a small spacer under the end of the Aluminium angle which holds the guilty bearing, once you get it touching tighten the bolt up a bit and check to see that the bearing is still touching the pipe.
Jason
Old 12-04-2006, 11:07 PM
thanks for the help
