Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 11-02-2006, 03:44 PM
sala84 is on a distinguished road
Bearing
hello!!!the bearing are 8*22 mm o 0.8*0.22 inches???
Old 11-02-2006, 04:11 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I believe most bearing designations are metric so it is likely 8mmX22mm which is a 608 bearing and is very common.
(I am now ducking to avoid the wrath of NCCams, who will beat me severely if this information is less than 105% accurate and complete)
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 11-02-2006, 05:38 PM
NC Cams is on a distinguished road
If it is 8mm x 22mm x 7mm, it is a 608 and yes, it is a very, very common small motor bearing.
HOWEVER, router bearings tend to be "specials" in that they are highly tested and/developed items.
That is, the seals, grease, grease fill and clearance are finely tuned to make a lowly 608 live in most electric motor applications. Generic 608's may work but they might not live as well as the OEM parts did.
I only beat people when/if they really deserve it. Otherwise, merely the fear of retribution usually suffices in keeping the troops in order....
Old 11-03-2006, 02:13 AM
yes i understund but the speed isn't very hight for the live of bearing.
Mhhhh i'm italian and my english is very bad!!!!
Old 11-03-2006, 09:28 AM
mxtras's Avatar
Silver Member
Your English is much better than our Italian!
Scott
Old 11-03-2006, 10:31 AM
anyone can send me the steel tube at a good price???
Old 11-03-2006, 10:36 AM
mxtras's Avatar
Silver Member
Can't you get pipe in Italy? You might have to modify the design to use a different size pipe but it seems easier to do that than to try to import a length of pipe or two.
Scott
Old 11-03-2006, 10:42 AM
yes....i'm crazy!!!
