Hello All,
Well I am just wondering if I build the JGRO per plans what is the actual cut table size ie just how much cuttable travel do you have? Not sure if that makes since try this if I plunger the router at its exterme left and cut to the extreme right on the x axis (X is the wide part right not the length?)how long is the cut same with the y axis? I am just wondering if it will be big enough I need to be able to cut at the largest a square that is 36" long by 24" wide can the jgro per plans do this if not how much bigger will I need to scale the plans for the X and Y axis to accomplish this size cut?
