Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 01-13-2006, 02:15 PM
randyf1965 is on a distinguished road
JGRO questions
I am using Alibre Xpress to model the JGRO and have questions ... Please do NOT move the thread...
Anyway the gantry sides have 3 blind holes on the lower front spaced at .375 , 1.438 and 2.5 and the gantry front has 3 holes at .375 , 1.375 and 2.375.
Should these holes not align?
Old 01-15-2006, 10:43 PM
Next issue....
From the jgro router, the y linear bearing angles.... the 90 degree edge has 2 spots that are chamfered..... HOW can I do this? I can chamfer the entire edge
Old 01-15-2006, 10:48 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by randyf1965
Next issue....
Use a grinder, it is only there to get the head of the bolt low enought so it does not hit the pipe rail.
Old 01-15-2006, 11:12 PM
ger21's Avatar
Is this an Alibre question?
Old 01-15-2006, 11:21 PM
Madclicker is on a distinguished road
Next issue....
Certainly don't flatten the whole edge! It will severely weaken the angle.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 01-16-2006, 12:30 AM
joecnc2006's Avatar
www.joescnc.com
oops i should have caught on to that... lol
Old 01-16-2006, 08:12 AM
HAHAHA
Sorry, yes Alibre related question...
I assumed the holes I mentioned in the 1st question were supposed to line up.
Old 01-16-2006, 08:45 AM
ger21's Avatar
Not sure what they call it in Alibre, but you create a "cutting" part and subtract it the chamfered part.
Old 01-16-2006, 01:23 PM
I had to add a new plane 45 degrees to the x axis on the corner of the angle. Then I was able to draw the rectangle for the cutout and extrude cut it down .125" .
This is a VERY cool tool for a free app!
Learning alot about how the router is built without wasting wood!
Name:	Y Linear Bearing - cnc_dtl25.jpg‎
Old 01-16-2006, 04:10 PM
Wolfspaw is on a distinguished road
You could also create a plane parallel to the end of the angle offset the distance to the hole. Then project the outer 90 degree edges of the angle to that plane. Add a line at 45 degrees to form the triangular chamfer shape and then trim the projected lines to it. Then extrude-cut the sketch midplane to the desired length.
There are many ways to achieve the same result. Stick with what works for you.
  #11   Ban this user!
Old 01-16-2006, 05:11 PM
I am sure there are a bunch of different ways to do things.... problem is when you don't know what they call what you want to do , makes it hard to look it up in a manual!
So I ask questions and use trial and error... save the part before I try something strange in case I can't undo it.
  #12   Ban this user!
Old 01-26-2006, 08:18 PM
Not a question but I have all the pieces drawn and am starting to put together the assemblies......
The 2nd picture is the replacement gantry for my router (once it is finished and can make it's own replacement parts!) 5'6x10.5"x3" (I think) using 1/4" plywood Joe2000che-style. Outer skin removed to show inner torsion assembly, the 2 hard points on both end are 3/4".
Name:	Gantry Assembly - Alibre Design Xpress(1).jpg‎
ID:	14199   Click image for larger version
Name:	New Gantry Assembly - Alibre Design Xpress(1).jpg‎
