Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
  #13   Ban this user!
Old 01-17-2007, 09:02 AM
bisclavret's Avatar
bisclavret is on a distinguished road
Originally Posted by randyf1965 View Post
Next issue....
From the jgro router, the y linear bearing angles.... the 90 degree edge has 2 spots that are chamfered..... HOW can I do this? I can chamfer the entire edge
I used a flat file. I could have used my grinder, but the file was quicker.
  #14   Ban this user!
Old 01-18-2007, 08:29 PM
HayTay's Avatar
HayTay is on a distinguished road
Anyway the gantry sides have 3 blind holes on the lower front spaced at .375 , 1.438 and 2.5 and the gantry front has 3 holes at .375 , 1.375 and 2.375.
Should these holes not align?
I just noticed that no one has answered this question. Good attention to detail, randyf1965.
Yes the holes should align. I didn't catch it when I measured and drilled the Gantry Front (CNC_DTL20). The three holes should be spaced at 0.375", 1.438", and 2.500" to match the bolt and dowel pin holes in the Gantry - Left Side (CNC_DTL16) and Gantry - Right Side (CNC_DTL17).
I had to break out the oblong drill bit to make some oval holes to correct the alignment problem that arose from the incorrect drawing dimensions, but it all worked out OK.
HayTay
Don't be the one that stands in the way of your success!
