Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 12-30-2005, 11:20 AM
wallyh is on a distinguished road
JGRO Design OK for First Machine
I'm new to this but I've spent a couple of weeks looking at posts. I would like to build a machine for hobby use, cutting out model airplane parts (balsa and light plywood).
Would the JGRO router table design be a good first machine to build? I have wood making tools, such as: table saw, drill press, jig saw, etc. I have downloaded the plans and, with help from you all, I think that I could build it.
I thought before I started collecting material I would ask for your opinions. perhaps there's another plan I should look at or even a kit that maybe is out there. I don't think I need a large machine for what I want to do.
I hope this is the right forum for this question.
Thanks in advance, Wally.
Old 12-31-2005, 02:34 AM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
You are on the right track. The jgro build is the simplest and most accurate for the money and time spent to build. You should read the following thread by joe2000chevy. He has great ideas on building this style of machine and you can get a good education from the thread. The thread is found at:
Joes 2nd Machine
Additionally is his latest build at:
Joe's CNC Model 2006
Really, the guy is a genius and you can learn a lot from his build journals.
Good luck and post your progress with pictures.
Old 12-31-2005, 07:50 PM
Thank you for the threads, I just finished going through them and all I can say is wow! It looks like I have my work cut out for me. Question: what's the difference between HDPE and UHMW? Can these materials be interchanged? i can get UHMW easier than HDPE.
Wally
Old 12-31-2005, 09:06 PM
acondit's Avatar
acondit is on a distinguished road
Wally
I cut a drive nut for an acme screw out of UHMW and couldn't get the nut loose enough to use. Then I cut one out of Delrin and it was right on first try. I think the delrin doesn't deform as much under pressure. (My opinion only)
Alan
Old 04-30-2006, 02:50 PM
triticale is on a distinguished road
I've seen the suggestion of freezing UHMW before the final tapping pass. The presumption was that it expanded, but maybe it no longer deforms away from the tap.
Old 07-14-2006, 09:09 PM
mindstorm88 is on a distinguished road
Hi guys, with the JGRO original plan , without any mod , what is the usable cutting area ????
Old 07-15-2006, 10:48 AM
HayTay's Avatar
HayTay is on a distinguished road
The cutting area is approximately 15" x 30" (381mm x 762mm). You can do slightly longer pieces if you want to hang them over the end of the table.
The JGRO is a great, first CNC table, you'll learn a lot.
HayTay
HayTay
Don't be the one that stands in the way of your success!
Old 07-15-2006, 09:43 PM
Madclicker is on a distinguished road
Freezing shrinks. Maybe warm the tap and cool the uhmw?
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
