Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 11-23-2005, 05:23 PM
ArcadEd is on a distinguished road
Wow, cool stuff. A few questions
Hello, I was doing some research on CNC routers today and decided to look and see if there was a DIY solution. To my suprise, there was.
I'm curious how big the jrgo cnc router is? You see make these arcade boxes (www.arcadeinabox.com) The largest piece being the control panel at 17" x 33"
Will the plans make a unit capable of cutting a wood piece that large?
Also, can you do cuts all the way through the wood with this setup. Seems like you would need to have some scrap wood underneath what you are cutting to make this work.
One last question, what is the average total cost for tackling a project like this.
Thanks again and I will spending my next 4 days from off from work reading through this whole place .
