Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 11-20-2005, 10:40 PM
mrbaseball is on a distinguished road
How many limit/home switches to buy for 3 axis
I'm at the stage in acquiring parts for my machine and need to know how many limit/home switches are needed for a 3 axis router. Am I right in assuming that I need 3 home switches and 3 limit switches?? The home switches tell the software where "home" or the start position is? and the limit switches are used to tell the software where the end point is for travel??
What kind of switches is everyone getting?? Simple push button switches that can be bought at Radioshack??
http://www.radioshack.com/product/in...entPage=search
Old 11-21-2005, 09:20 AM
anyone???
Old 11-21-2005, 09:50 AM
ger21's Avatar
If you want to use your home switches as limits, you'll need 6 switches. You can also place your home switches in between your limits, in which case you'd need 9. I think most people go the 6 route. Something like these are used a lot.
http://www.radioshack.com/product/in...entPage=family
Old 11-22-2005, 06:01 PM
*Registered User*
twombo is on a distinguished road
Or.... If using Mach 2 or 3, and "PC 2 Route" breakout board, one can use proximity switches... one per axis.
Check out Bob Campbell's website:
http://www.campbelldesigns.com/breakout-board.php.
for the PC 2 Route breakout board.
I use these inductive sensors from Automation Direct:
http://web6.automationdirect.com/adc/Shopping/Catalog/Sensors_-z-_Encoders/Inductive_Proximity_Sensors/12mm_Round_(AM-z-VM1-z-PMW_Series)/Standard_Sensing_Distance_(AM1_Series)/AM1-AN-1A
Pretty slick little items.
Mike
Old 11-22-2005, 10:41 PM
I'm using thre hobbycnc 3 axis board so I will setup the limit switches with this
