Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
  #13   Ban this user!
Old 11-18-2005, 04:38 PM
carlnpa is on a distinguished road
I ran the machine about 5 hours today, just cutting air while I had the other machine going on parts. The modification of the x axis was very easy. The bearing slides really well and better with some silicone lube spray. I had not removed the acme screw (didn't want to mess with my AB nuts) so using the screw as a handle I could give the gantry a push and it would slide to the end of the rail+. No issues, works as expected, much better than the roller/pipe bearing, not as rigid as a steel linear bearing and rail. Was able to get up to 80 IPM before missing steps with 200oz motors (was at 40IPM before).
  #14   Ban this user!
Old 11-19-2005, 08:34 PM
mrbaseball is on a distinguished road
Hello everyone,
I'm making this one revision to the jgro router design for my own use. It is for the y axis gantry. I got the idea mostly from Anoels build photos. I have this drawing in Illustrator and would like to output it to the correct dimensions for tracing onto the mdf. Anyone have any ideas as how I can do this??
Name:	cnc-side copy.jpg‎
  #15   Ban this user!
Old 11-20-2005, 02:38 AM
soundman is on a distinguished road
I use illustrator a lot for drawing up plans for rc planes - the easiest & quickest way is to draw some square guidlines on the image in a different colour to the main constuction lines. Then print the file out tiled onto as many pieces of paper as needed - trim the bits of paper to some of the square guidlines that you drew before & tape together.....then trim out the part that you want & stick it onto the wood with adhesive spray mount (the repositional type) then trace round or cut around the pattern.....this works for me - others may have a different way.
  #16   Ban this user!
Old 11-20-2005, 08:47 AM
jasonmarkham is on a distinguished road
hi ,
i've been reading posts for the last week, i would like to build a pcb cnc mill, so far i didn't find any plans .
Kindly can you please tell me where i can find such plans for an a4 cnc ?
thanks and regards
Jason Markham
