Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 10-14-2005, 07:10 AM
Twin-X is on a distinguished road
question about it's capabilities
Hello,
Is the JGRO build good enough to engrave / cut 3mm thick aluminum panels?
I need to build something for the engraving of enclosures but i have 0 experience.
I wonder if this machine can handle it or maybe it's too powerfull?
1 thing is sure it's very big for the panels i wish to engrave / cut.
Regards,
Jeffry
Old 10-14-2005, 09:11 AM
Jason Marsha is on a distinguished road
A well built JGRO can engrave aluminium with no problems, you must however appreciate that the machine is constructed from MDF so you will have to cut more slowly than if the machine was one of metal construction.
Jason
Old 10-14-2005, 09:35 AM
Jason
Well i am not going to use it for mass production anyway.
Thank you for the info!
Old 01-23-2007, 02:00 PM
ifeliciano's Avatar
ifeliciano is on a distinguished road
Jason
So if one would build it from a marine grade Baltic Birch. could the cut rate be higher vs. MDF ?
Old 01-23-2007, 02:50 PM
Coogrrr's Avatar
Coogrrr is on a distinguished road
or?
or what about HDPE?
Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
Old 01-23-2007, 09:53 PM
I suspect the rate is about the same.
Jason
