Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 10-24-2011, 08:22 AM
Jimn is on a distinguished road
New JGRO build
Hi, I've just started building a JGRO CNC, building from 3/4 inch Birch Plywood rather than MDF. I've started with the Z axis pieces and almost have that part complete. The actual build should not be a problem, as I've been a hobbyist woodworker for years. My question to the forum, is about the motor drivers. I'm pretty sure I want to use a bi-polar driver due to the increased torque from a motor in bi-polar mode vs uni-polar. I have a couple Big Easy driver boards that I bought from Spark Fun Electronics, which seem to be quite nice, but, I'm worried about their ability to handle the rated 2A for long periods of time, even with heat sinks. I found the TB6560 boards on e-Bay, and they looked great until I started reading about them. All of the reviews I read about these boards are from a couple years ago. Since I haven't seen any newer comments about these boards, have they been revised and are now relatively good, or have people just stopped using them? Any direction would be appreciated.
Old 05-01-2012, 04:48 PM
Garage Elf is on a distinguished road
I know this is a late reply, but I've had success with the TB6560 boaard...so far. PM me if you need some help & I'll do what I can.
Old 05-01-2012, 05:31 PM
jckstrthmghty is on a distinguished road
you may want to save the nice ply and your $$ for you next build. The unsupported rails will not be able to take advantage of the superior rigidity of the ply over mdf. If you have the money to spend then it might even be better to just buy a joes2006 kit if it's still avaliable.
Tags
driver board, new build, tb6560
JGRO Build Build JGRO Router Table Design 1 05-25-2011 06:12 PM
Jgro cnc build Log tbenefi33 JGRO Router Table Design 54 10-19-2010 03:17 PM
New JGRO build gylron JGRO Router Table Design 9 07-09-2008 06:43 AM
going to build the jgro clammy23 DIY-CNC Router Table Machines 0 01-04-2007 05:44 AM
Yet another jgro build bnoble JGRO Router Table Design 2 11-16-2005 09:51 PM
