Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
  #13   Ban this user!
Old 10-05-2005, 03:00 PM
santiniuk's Avatar
santiniuk is on a distinguished road
Originally Posted by Sporqster
thanks
Here's a trick for hiding or showing constraints- hit CTRL-F - brings up the search screen. search for: Constraints
hit the select button, and then right click on any one of the selected constraints and select "hide". It'll hide all of them including the ones in subassy's.
I think I've got a macro that'll do that too... what did I do with it?!?
Very useful tip. Thanks for that one. If you come across the macro It would be ideal.
I don't have the feature to export as an .exe however I have exported as a vrml file that is quite useful. I suspect it may require a decent spec machine to view it and manipulate.
A VRML plugin is available here :-
http://www.parallelgraphics.com/products/cortona/
Hopefully the Catia export should be attached.
Cheers.
