Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 04-27-2011, 06:53 PM
wixy is on a distinguished road
Drill press needed for build?
I'm looking at building a JGRO cnc and am wondering if a drill press is needed or can I can get away with using a cordless hand drill?
Old 04-28-2011, 10:27 AM
hazardouschurch is on a distinguished road
Drill Press
Well it is dependent on your skill level with wood and how accurate you want your machine. If you want more accuracy then use a drill press but if you don't want to spend $$ on a drill press then just use the hand drill. The plans are not set in stone if you drill within .05" then your well off. If it need a little adjusting later on then just wiggle the bit a little to get it to fit. Plus MDF is cheap so if you mess up it would be easy to replace. The plans are just really explanatory guidelines make the machine to what fits your needs.
Old 04-28-2011, 07:44 PM
Jason Marsha is on a distinguished road
You need a drill press!
Jason
Old 05-10-2011, 08:04 AM
voltsandbolts's Avatar
voltsandbolts is on a distinguished road
I don't recall using a drill press when I built mine. But if you have one, use it.
I think after I cut my parts I laid out all the holes in pencil, center punched and hand drilled them.
Rob.
Deeds not words...
VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/
Need Help!- Drill Press rwhubbard Want To Buy...Need help! 0 10-10-2010 04:15 PM
Need Help!- Drill Press SheldonB General Metal Working Machines 0 04-11-2010 02:51 PM
drill press mod tbenefi33 Wood Lathes / Mills 1 02-24-2009 04:49 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
