Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 06-20-2005, 03:45 PM
bcromwell is on a distinguished road
Pipe Bearing Adjustments (JGRO)
I sure this has been covered but I can't find it with the search function,
Anyone have suggestions on how to align the pipes on the jgro machine? I have been trying quite a bit and keep having one or more bearings not touching. I believe the pipes are strait, but I am planning on taking them out and double-checking.
Suggestions would be greatly appreciated.
Old 06-20-2005, 05:04 PM
sol sol is offline
Gold Member
sol is on a distinguished road
I have not worked on the jgro machine but have worked on similar alignment issues with other home-builds that use the same system.
With the adjustment bolts loose except for the bottom ones which have been adjusted for level...Use long clamps or wrap both rails together with rope on each side of the trucks and tighten so they load up the bearings. Tighten the pipe holding bolts incrementally while going from one to another. Keep checking for square and level.
It can be aggravating....
Old 06-20-2005, 05:16 PM
jgro's Avatar
Gold Member
jgro is on a distinguished road
Look here: Free Router plans! and Discuss it here. post #93. I gave a short description of how I did it. Hope this helps.
jgro
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 04:12 PM
Torsion box and Skate bearing thought spalm Linear and Rotary Motion 0 06-03-2005 04:19 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 05:52 PM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 03:03 AM
