Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 08-23-2010, 05:06 PM
buschhoff is on a distinguished road
Bushy's JGRO Build
HELLO CNCZONE
I’ve joined the forum to learn from experience and I have… Just recently saved enough money for everything … I am building a JGRO.
DAY 1 - My first pieces to build are the Torsion Beds.
So I printed out a cutout diagram using CUTLIST.zip. Always double check the sizes before printing. I went to Home Depot and had them cut the large bed tops and (10)1-1/4” & (10)2-1/2” x 48” lengths. I can cut to size on miter saw.
Name:	CUTLIST LAYOUT 1-2.jpg
ID:	113292 Click image for larger version
Name:	DAY 1 - pic 1.jpg
ID:	113293 Click image for larger version
Name:	DAY 1 - pic 2.jpg
ID:	113294 Click image for larger version
Name:	DAY 1 - pic 3.jpg
Old 08-23-2010, 09:17 PM
nuplowboy is on a distinguished road
Welcome to the 'zone!
The JGRO was my first (and only so far) router too. It's a pretty good beginner design. Fairly easy to fabricate.
I think several folks on here have suggested adding a skin to the bottom of the bed's torsion box to make it a real box. I built mine per the plans with the bottom open, and it'll eventually start to sag a bit...
Have fun!
Old 08-25-2010, 09:44 PM
DAY 2 - Bushy's JGRO Build
DAY 2 - Go Shopping, Finish Second Torsion Bed.
So I printed out a 3/4" MDF cutout diagram using CUTLIST. I went to Home Depot and had them cut the top bed, bed ends and various size lengths. I can cut to size on miter saw, again. Next I went to Lowes for Hardware, Screws, Bolts and Nuts... Slightly cheaper and they had the Aluminum Angles. NOTE... I will be using 5/16-18 Threaded Rod.
I had to Order a Number of Stuff from Online...
Hitachi M12VC 2-1/4 HP Router, T-Tracks, Delrin Sheet, HDPE Sheet and bearings.
I had Ordered and Received the Electronics Package from FINELINEAUTOMATION. Very well Price and Super Fast Shipping. Thanks Nate.
Name:	CUTLIST LAYOUT 3-4.jpg
Sorry No Pics of Second Torsion Bed.
Old 08-26-2010, 08:09 AM
Jason Marsha is on a distinguished road
Looking good so far. Build it well and it will serve you a long time. Make sure to give it a good paint job as well.
Jason
Old 08-27-2010, 07:35 PM
DAY 3 - Bushy's JGRO Build
Day 3 - Cut lengths to size for all 3/4 MDF on Miter Saw.... No Problem.
I started working with the drill press to cut the 1-1/2" holes in the 1-1/2" glued together MDF pieces for the bed end and PROBLEM.... My motor burned out on my 1/2 HP Drill press.
Time to go shopping again for a new Drill press and not by choice.... That $15 drill press was great and cut hundreds of pieces
Old 08-27-2010, 07:43 PM
bobsch's Avatar
bobsch is on a distinguished road
Why not replace the motor?
Bob
"Bad decisions make good stories."
Old 08-27-2010, 11:01 PM
Broken Drill Press
I managed to borrow an old 2/3 hp drill press... I want to get this build done.
I will probably rebuild my old McGraw Edison 1/2 HP Drill Press Later, After the build.
Old 10-15-2010, 10:23 PM
Day 15 or so??? - Assembly
I lost count of how many days I have been machining parts but everything is cut. I'm sorry for not taking photos during the whole process, I never remember my camera.
I started assembling today and I can't believe how strong this material is bolted together.
Name:	DAY 15 - pic 1.jpg
ID:	116937 Click image for larger version
Name:	DAY 15 - pic 2.jpg
When I finish the project, I will have some final notes etc.
Old 11-05-2010, 04:16 AM
Finally Connected and NEED HELP
The Machine is hooked up... I'm Running EMC2 on a Dual Processor 1.8 Ghz MB w/ 512 MB of RAM. I bought a gecko G540 and motors from FINELINE Automation.
I have several issues I need HELP with
1. How do you get the Charge Pump to work in the ON Position?
I couldn't get this possible solution to work
Does anyone have a profile for EMC2 w/ the Gecko g540 attached to the JGRO?
2. My 5/16" Screw rods keep loosening at the bearing ends... How do I fix this?
3. The Y axis may be on a slight pitch from one side to the other, can this hurt the motor? How should I fix this?
4.
Where do you have your limit switches?
5.
How did you hang your wires?
Old 11-10-2010, 01:41 PM
Some pics to help.
These pics show the rod locked in from both sides of the bearing attached to the machine. The bearing of the motor does not support the lead screw.
Use locknuts, they are a brute to go on but they won't back off.
ID:	118849   Click image for larger version
  #11   Ban this user!
Old 11-10-2010, 01:49 PM
Limit switches and cables.
ID:	118851   Click image for larger version
ID:	118852   Click image for larger version
ID:	118853   Click image for larger version
09-07 jgro build CNC-Dad JGRO Router Table Design 3 02-22-2012 09:23 PM
Jgro cnc build Log tbenefi33 JGRO Router Table Design 54 10-19-2010 03:17 PM
New JGRO build gylron JGRO Router Table Design 9 07-09-2008 06:43 AM
My JGRO build Sieg JGRO Router Table Design 46 10-31-2007 08:36 AM
Yet another jgro build bnoble JGRO Router Table Design 2 11-16-2005 09:51 PM
