Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 06-07-2005, 05:20 PM
Ayjay is on a distinguished road
Parts For JGRO
Well I am about to take the plunge and attempt a build of the JGRO Router. I am in the process of sourcing out materials and supplies and as I read through the plans I didn't see a part # for the flanged bearing from Mcmaster & Carr. I did a search at their website but that only confused me (more than I already am, that is). Does anyone know what that part # is?
Also, I have a small supply of UHMW plastic on hand which I'm thinking may be a better material for the adjustment blocks than MDF. Also, could UHMW be substituted for the delrin in the anti backlash nuts and the anti whip block?
Love this site and I am sure I'll be posting again looking for more advice as the build progresses
Don't sweat the small stuff - and there ain't no big stuff!
Old 06-07-2005, 06:43 PM
Gold Member
ignatz is on a distinguished road
I think the part number you're looking for is 6383K12 (for 1/4"). You can search for "Steel Semi-Precision Ball Bearings" or catalog page 1014. I know that when I started I had the same question and answered it by reading Jgro's original thread. Its near the end but he also give a part number for the aluminum channel.
I'm pretty sure that UHMW can be substitued. I think some people have even used plastic cutting boards.
I hope this helps.
Old 06-08-2005, 02:31 PM
Thanks for the info Ignatz. I think the correct number for the flanged bearing is 6383K13, but the info you provided sent me to the right page . Thanks again.
I will be starting the build soon and will probably start a build log with photos etc.
Old 06-08-2005, 03:01 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
yes i use the poly for my adjustment blocks and it works great. infact i will be cutting the whole machine out of 3/4" Polyetheline. and sell them. It will be the size of my new machine.
Old 06-13-2005, 07:53 PM
Ursine is on a distinguished road
Joe,
Interesting idea about the polyethlene (UHMW?). Will it be ridgid enough? How easily does it machine?
Dave
Old 06-13-2005, 08:49 PM
joecnc2006's Avatar
www.joescnc.com
It works really well, its HD Poly.
Old 06-14-2005, 02:34 PM
randyf1965 is on a distinguished road
a bit more expensive than mdf.... found a 3/4"x54"x96" sheet for $259 or a 1" think sheet for $345
They show this stuff being used for boat ladders so it must be strong
Old 06-14-2005, 03:34 PM
Check out McMaster Carr
http://www.mcmaster.com/itm/find.ASP...tring=8619K118
3/4 thick 4 X 8 sheet of HDPE $185.23. I think this should be ridgid enough.
Dave
Old 06-14-2005, 03:57 PM
joecnc2006's Avatar
www.joescnc.com
Dave
With shipping it would be expensive unless you are local to them. I get it local for 188 a sheet and they cut it for me into (4) 24"x48" pieces and fits right on my cnc machine.
I will be offering my machine completely cut out of this or any parts people like, would make good linier bearing block supports or any other things people that are interested. Will make an excelent machine, just add motors and controllor
Old 06-15-2005, 04:04 AM
[QUOTE=joe2000che]With shipping it would be expensive unless you are local to them. I get it local for 188 a sheet and they cut it for me into (4) 24"x48" pieces and fits right on my cnc machine.
That is the size I am building..... but I am going 4' on the Y axis (gantry width) and 2' on X for possible future expansion .... easier to build a new 8' table than having to rebuild both!
Cnc Parts Parts And More Parts berin CNCzone Club House 2 07-27-2010 03:21 PM
RFQ two Aluminum parts, cheap no rush mike_r Employment Opportunity 0 04-28-2005 11:14 PM
Boss8 parts - what are they worth? fastturbovet Bridgeport and Hardinge Mills 1 04-08-2005 07:47 AM
Alternative material for gantry parts owhite DIY-CNC Router Table Machines 3 02-10-2004 01:26 AM
Custom Car Parts Gujustud CNCzone Club House 4 11-03-2003 09:53 PM
