Free Router plans! and Discuss it here. - Page 33
Page 33 of 33 FirstFirst ... 2330313233
Results 385 to 392 of 392
Thread: Free Router plans! and Discuss it here.
  1. #385
    Nov 2007
    If you can get the parts cut the joes2006 is a much easier build. The major issue with the JGRO is you have to adjust every rail and leadscrew. Once setup it's good but getting there is time cosuming and fustrating at times in my experience. Not to mention deflection even after everything is lined up. With the joes2006 you assemble square and you are off.
    I think there is a link in the joes2006 portion of the forum. Somewhere at the beginning. You want the second version. All the files you need to cut on a CNC are there. I recommend you read that entire forum. Great info there.
  2. #386
    Nov 2012
    canada
    I'm looking through it, and I think you've convinced me to build the joes 2006 r2 - I can't view the drawings from work, but I'll check them out, and try to get a price from someone to cut the parts for me. Thanks for the advice - you are right, the JGRO is very fussy to get adjusted properly - and really easy find the limits of the machine's abilities. Hopefully the Joe's will be much easier and better in many regards.
  3. #387
    Sep 2013
    Default JGRO Plans
    I'm looking over the files for the JGRO CNC Machine. There seems to be a descrepancy between dtl101 and dtl102 (Support Motor Side & Support Bearing Side). The tapped holes for gas rod supports are not the same distance from the center line of the gas rod hole. Am I reading the diagram incorrectly? Thanks
  4. #388
    Gold Member jgro's Avatar
    Jul 2003
    The holes that are dimensioned on dtl101 are for the stepper motor, which have a different spacing than the rod support blocks. All of the holes for the gas pipe support are the same. You can use the dimensions from dtl102 for those.
    jgro
    http://jgroshoppages.blogspot.com/
  5. #389
    Registered gividen's Avatar
    Jan 2008
    Default Re: Free Router plans! and Discuss it here.
    Quote Originally Posted by cncadmin View Post
    Here is the link for the free router plans www.cnczone.com | 404 - Page Cannot Be Found please discuss the plans here in this thread.
    The link is not working for me.
  6. #390
    Jul 2003
  7. #391
    Jan 2008
    Quote Originally Posted by jgro View Post
    I followed the link and I got a blank page using Chrome for Android. Is the link still valid?
  8. #392
    Administrator shuwal's Avatar
    Sep 2016
    Chicago
    Quote Originally Posted by gividen View Post
    I followed the link on Chrome desktop Version 57.0.2987.133 (64-bit)
    It isn't dead.
    Mike
    Free Router plans! and Discuss it here.-its_notdead_jim-jpg
