Markg:
Explain further how the encore wing is made? I'm not getting it from the article. Maybe its just reading it on line. I understand the first side of wing surface is cut in the missionary position. I'm mean, nothing fancy, it just lays there flat. But once that surface is cut, a female form is used to hold the flipped wing? So a separate negative surface must be cut too? And, its the negative surface that has the vacuum holes right?
Dave
