JGRO Pics Finally - Page 5
Page 5 of 17 FirstFirst ... 234567815 ... LastLast
Results 81 to 100 of 337
Thread: JGRO Pics Finally
  1. #81
    Registered Rance's Avatar
    Jan 2005
    US (22405)
    Jason, Nice Job. I'd be interested in the g-code for that if you wouldn't mind posting it.
    Maybe a better place to post the g-code might be http://www.cnczone.com/forums/forumdisplay.php?f=152 . Actually, I think it might be nice to have a new category under 'Machine Controllers Software and Solutions' (http://www.cnczone.com/forums/forumdisplay.php?f=69) just for posting shareware g-code).
  2. #82
    Dec 2004
    Barbados
    No problem Rance, I will post the 5/16 hole size as well as the 6mm hole size (motor shaft) and the star, the 1/4" hole code needs a correction.
    *********The code is in mm!**********
    ********Please note that the code requires use of a 1/8" bit.*********
    *************The 1/8 bit should have a 1/2" Depth of cut.************
    Jason
    Attached Files Attached Files
  3. #83
    Dec 2004
    Barbados
    Joe,
    I forgot to indicate my set screws are 3/8" long so I have thread contact right through the stock to the shaft hole. What was the length of your set screw?
    Jason
  4. #84
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Quote Originally Posted by Jason Marsha
    Joe,
    Jason
    Oh ok that will help alot mine were really short.
  5. #85
    Dec 2004
    Barbados
    I decided to get some Lovejoy Couplers for my JGRO, I found some at Surplus Center at $2.19 for each half plus $1.49 for the insert, a total of $5.87 each. I did not know they were that cheap so I bought 6 - 1/4 halves , 6 - 5/16 halves as well as the inserts. The extra couplers will go on my Hawk mill for now as I have not had the time to fit the homemade ones.
    These couplers are allowing me to jog at a faster speed as compared to the rigid couplers which leave no room for error.
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-lovejoy-coupler-jpg
  6. #86
    Dec 2004
    Barbados
    The lovejoys are working well but I noticed as others did that the rubber spider inserts allow a little backlash if the size is slightly off. I therefore tried my hand at designing and cutting out some inserts as Joe did and they came out quite well.
    I am yet to determine the performance of the home made inserts but I will post it in the zone.
    The good thing about these small parts is that they can be produced from offcuts of material lying around.
    I have not had a chance to test the plastic couplers on the little machine yet
    but I should have time this weekend
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-coupler-compare1-jpg   JGRO Pics Finally-coupler-compare2-jpg   JGRO Pics Finally-coupler-compare3-jpg
  7. #87
    Dec 2004
    Barbados
    Here is the code for the lovejoy L-050 inserts.
    This code requires a 1/8" bit to be used.
    The center of the insert is coordinates 0.0, 0.0 .
    The code is in mm.
    Max depth of cut is 12mm. (1/2" = 12.7mm)
    Jason
  8. #88
    Dec 2004
    Barbados
    I cut a set of curtain rod brackets for a friend, 22 in all. The bottom is to be routed with 3 small semicircles. The final paint finish was her job.
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-curtain-brackets-jpg
  9. #89
    Dec 2004
    Barbados
    Made some adjustments to the inserts. code posted below.
    Jason
  10. #90
    Dec 2004
    Barbados
    Here is a pic of the two versions.There is a third version but its a little loose.
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-spider2-jpg
  11. #91
    Aug 2004
    Jason
    Here are the final ones i made, they fit very snug and no play in them, try it out and let me know, it is in inch's, 0.25 endmill, 0.5 stock.
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-lovejoy-smaller-version-jpg
  12. #92
    Dec 2004
    Barbados
    I will try it and let you know.
    What type of material are you using to cut the spiders?
    I am using a cutting board which is medium density polyethelyne and this requires a little finishing sometimes.
    Jason
  13. #93
    Aug 2004
    Jason
    DHPE 1/2" and a 1/8" carbide bit
  14. #94
    Dec 2004
    Barbados
    I tried the spider file Joe posted but used a 1/4" bit instead of 1/8" , I must be working too hard .
    Here are few pics of some work I am presently working on, a clock in the shape of a shield. This is a sample cut using plywood to give the client an idea of the expected results. The recessed square in the middle will hold a thin sheet of aluminum which will have a crest and some text in colour. My client can apparently print images onto the aluminum.
    The wooden curtain rod supports are quite popular as well, a friend wants me to cut 60 for him.
    Within the next week or so I should have a new router holder as well.
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-pocket-jpg   JGRO Pics Finally-clockshield-jpg
  15. #95
    Aug 2004
    The wooden curtain rod supports are quite popular as well, a friend me to cut 60 for them.
    Jason
    that looks pretty cool.
  16. #96
    Dec 2004
    Barbados
    The design is 20"tall and 14" wide. Total time 32min at 40"min with the pocketing using most of that time.
    Jason
  17. #97
    Dec 2004
    Barbados
    Thanks Joe.
    I almost forgot, I also got my little JCKlienbauer mill working. Here is a pic of the setup.
    The motors are a little weak so I am topping out at 30"min rapids.
    Jason
    Attached Thumbnails Attached Thumbnails JGRO Pics Finally-jckmill-jpg
  18. #98
    Registered litris's Avatar
    Feb 2006
    Spain
    Default Please!
  19. #99
    Dec 2004
    Barbados
    Well that batch of 60 curtain rod brackets was going fine through the cutting process until Mach3 kept on stopping due to a limit switch trigger. I thought it was a one off error until it happened one minute after restarting the program. I returned the machine to the origin (X0,Y0) switched the machine and the computer off.
    A couple of hours later I returned to resume cutting but again the switch was triggered 5 minutes into the cut. I thought Mach 3 would indicate the switch being triggered but on testing it became apparent that once the switch is released the light on the diagnostic screen would return to its unlit state.
    In order to ensure that a repeat did not occur I simply disabled all the switches until I can isolate the guilty switch. The other possibility is that one of the limit switch wires is frayed or broken internally and such a occurance would trigger an error.
    I should have it solved by monday hopefully.
    Jason
  20. #100
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    It could be noise on the lines. Try increasing the debounce, to maybe 2000 or even 5000 and see if that helps. Config>Logic
    UCCNC 2017 Screenset
JGRO Pics Finally
JGRO Pics Finally
