I have seen the diffuser blades milled, without CNC control.
Have you read Shreckling's book on model gas turbines ? His method uses timber construction (small good quality plywood) for the compressor wheel. Its worth a read even if you don't intend to build using his methods.
I have building a gas turbine on my list of things to do, just too many things higher on the list at the moment.
Russell.
LinkBack URL
About LinkBacks
