Build Thread 1.st stage axial compressor designed with DIY automated CAD construction workflow
Results 1 to 2 of 2
Thread: 1.st stage axial compressor designed with DIY automated CAD construction workflow
    Registered Harpye's Avatar
    Jul 2007
    Germany
    Default 1.st stage axial compressor designed with DIY automated CAD construction workflow
    Hello Guys - here is my first attempt on an axial compressor for jet enginge purposes. to go easier with the free form surface design I wrote an automatism in Cad Scripting under Rhino VBR
    Attached Thumbnails Attached Thumbnails 1.st stage axial compressor designed with DIY automated CAD construction workflow-einlass-jpg   1.st stage axial compressor designed with DIY automated CAD construction workflow-v1-s1-jpg
    Why reach for speed, when you could have precision instead!!!
    Feb 2006
    Default Re: 1.st stage axial compressor designed with DIY automated CAD construction workflow
    have you estimated the stage compression ratio? At such a small scale the blade airfoil matters less due to the Reynolds number. what is the compression ratio that you are shooting for when you have the stages done?
    Ray,
    Life is a choice, death is choice poorly made.
