| Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here. |
#25
| if its just foaming out of the top drill the top fitting for a 1/4 NPT then screw in a barbed nipple. take some clear plastic tubing and run it up towards your motor. basically you make a taller vent stack and no more oil dripping down the side of the machine. also i am a really big fan of using ATF in the gear head, i think it works great and foams alot less than the spindle lube or whatever is in the head. |
#27
#12 SWC Join Date: Mar 2007 Location: Canada Posts: 37 ![]() I have been having the same problem. Tommy told me to disconnect the ground and that did not help. I am not sure as to what to do next. I have been trying to get ahold of tommy for 2 weeks now. I am not familiar with the above possible fixes. Can anybody elaborate for me in laymans terms. The machine also leaks oil and grease like crazy from the z axis. Tommy says do not worry bout I am getting tired of ruining parts and clothes. Any suggestions? the machine only has 10-15 hours of run time on it. Thanks in advance After reading these posts i am looking at NOT buying a IH Mill. Perhaps the Novokon is a better unit. Being not a wealthy Guy when I read about someone NOT being able to contact Tommy for 2 weeks? I guess they want youre money and thats that .Glad i found this posting. Novokon has a outstanding reputation from what i have heard. |
#28
I have never gotten the impression that IH does business that way. Everything I have ever read about them is that IH is a stand up company. However I did read in another post that there was a death in the family recently. They are a small operation so that can throw things off the rails for a few months. |
#29
http://www.cnczone.com/forums/showthread.php?t=97852 "I'd like to add a probe to my recently deliverd NM-135 and take advantage of the G31 code in Mach 3. I've tried numerous e-mails and phone calls to Novakon for help, all to no avail. Hopefully I can get better results here." |
#30
BTW the icon beating his head was a mistake. I hadnt ever used those and didnt realize they were posting. |
#31
| I grounded my system per the voltage of the circuit involved. I have 4 different voltages to deal with. 5v pc & a 5v supply , 12v & 24v vfd & spindle board, and the big 77v supply. I had noise up the wazoo till I did the grounding of the negative terminals of all the different areas which were to the different boards. On the parallel ports board, I set a grnd from a grnd to the panel. On the spindle board, I set a grnd from 5v grnd to panel and also the 12v grnd to panel. Maybe I should go look to be sure I am saying this correct, but the point is that this is the one and only thing that made my system perfectly quiet and reliable and now I can really run the machine. to clarify a little, I used an unused neg terminal from each system as well as the boards grnd point if it had one. and this worked. Now, as I understand it, a ground has a neg potential equal to the voltage of that circuit. So If you join two grnds of different potential then you have a ground fault ! The potential of the higher voltage will influence the lower potential and cause havoc to arise to the point of possible destruction of vital components. I am not an expert, so this may need to be further clarified but it is reasonably close to accurate. I hope ! Chassis grnd should be grnd'd to earth and as such should be considered earth grnd. This is where you want the noise potential to go to, direct path to Hell ! Bob ? Did I say this correctly ?
__________________ Don IH v-3 early model owner |
| My mill motor stops. What is wrong? | jaru-eri | Taig Mills & Lathes | 7 | 08-10-2009 10:14 AM |
| I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol | spunky1974 | Shopmaster/Shoptask | 0 | 06-30-2007 04:13 PM |
| Hitachi Spindle Stops for NO Reason | djc5975 | General Metal Working Machines | 1 | 11-15-2006 03:37 PM |
| I want one and now I have a reason. | rustranch | DIY-CNC Router Table Machines | 2 | 10-09-2003 10:58 PM |
| CNC for what reason? | WallCrawler | CNCzone Club House | 6 | 06-17-2003 11:30 AM |
