| Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here. |
| Im finishing up my 3rd 4 axis mill which is an IH and taking longer than expected. However, I have always been interested in a 5 axis machine and the possibilities of a diy model at home. I have seen a couple of model like the one at this youtube link, which I consider to be totally doable in a home shop. It's more of a 4th and 5th axis attachment but still gives you 5 axis machining capability. There are several diy 5 axis mills on youtube. |
| I think the main challenge will be getting access to affordable 5-axis software. Without this building a 5-axis machine will be like building a performance sports car without having access to the gas to run it. Just a thought Phil |
Hi, I am new here and this is my first post. It seems that the CNCZone would be a weath of knowledge through archives and posts.. So. I'd like to start of with building a 5-axis CNC machine that is tailored to workpieces that have radial symmetry. or maybe an x,y,z, + A-axis (about Z) and B-Axis about Y. The machine will be used for machinining metal, and hard metal.. Metal I refer to all hardness alloys of aluminum. Hard metal includes titanium, inconel, Hastelloy, etc. I also would like to machine wax models. The workpieces will be rotors, stators, nozzle rings etc, of upto 6 or 7 inches in diameter with Z of upto 5 inches. Anyone here can make recommendations of specific sources? As per the original poster, Software (Open SOURCE): EMC2 - tool controller GMAX12 - CAM tool CNCToolKit (Open Source) I plan using the above tools and even modifying the source code/recompile as needed. The biggest thing I am aimimg for is leveraging successful and well documented projects with similar capabilities. And BKMs (Best Known Methods.) I am not opposed to using Chinese Spindles, as I will design balancing tools and do the bearing change outs as needed. This skill will be required when I assemble my turbopump systems anyway. I know this is a wordy and tall order, but most of my past projects have been. What I can do in return, support others with engineering knowledge and or work in unison on respective projects. BTW, Thanks for reading through this post, Best, -RocketScientists |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 07:31 AM |
| New Machine Build- post for 2 axis ez trak versus 3 axis ez vision | tooolman | G-Code Programing | 0 | 11-28-2008 04:33 PM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 08:15 PM |
| One axis (z-axis?) computer controlled testing device | TsThorsell | Stepper Motors and Drives | 3 | 02-07-2008 01:38 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 03:58 PM |
