Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
  #13   Ban this user!
Old 08-31-2009, 08:41 PM
pete from TN's Avatar
pete from TN is on a distinguished road
Hey thanks man....
Look like the same item huh...peace
  #14   Ban this user!
Old 08-31-2009, 08:47 PM
HimyKabibble is on a distinguished road
Pete,
Did you get the drawbar pictures OK?
Regards,
Ray L.
  #15   Ban this user!
Old 08-31-2009, 09:09 PM
Ray....
Yup, sure did man, thanks for those, they will be helpful to say the least. I have some ideas about this that I gotta do some footwork on but I think that as you said it is definitely doable but not simple. Lots of bellville tension and some applied leverage and a stout cylinder of some kind. I read where you had some idea for a torque multiplier, care to share your ideas here? I tried to download that piece but it would not for some reason... There are actually a lot if interesting ideas about this problem in that thread you posted. Also your idea of limiting the distance an impact driver travels has merit too. I am with you tho in that the pneumatic or hydraulic setup is much quieter and more elegant solution. Gonna think on this one...peace
  #16   Ban this user!
Old 08-31-2009, 09:47 PM
Pete,
I attached a PDF of the patent with the pictures. But you can also go to google.com/patents, and download #5,273,264. Though I think the pneumatic/hydraulic multiplier is the way to go. It could probably be largely built with automotive brake/cluych hydraulics, or even from scratch.
Regards,
Ray L.
  #17   Ban this user!
Old 08-31-2009, 11:34 PM
TOTALLYRC is on a distinguished road
Limit configuration
man do I hear that.... and it all started when I thought gee I could build my own cnc machine and make a fortune!!! haha
That is some funny stuff right there man....
Just wondering how most of you guys have your limits configured. Do you put all your limits on one pin for home and one for limit or do you have individual pins designated? peace
Hi Pete,
I have one pin per switch because with the dspmc originally you had to do it that way. Rufi has now changed it to allow the home/limit combo. I am leaving it the way it is because you can see which limit switch is tripped, not just a general limit switch is hit. The leds on the diagnostic page.
There is no reason why you can't make a fortune with your cnc.
At least you own it outright and don't have to make payments on it every month.
Mike
Out of limits monte55 Machines running Mach Software 7 11-04-2006 09:28 PM
we all need limits! senor J. General Electronics Discussion 28 08-24-2006 12:06 AM
G-rex home and limits patrick71100 Gecko Drives 1 07-20-2006 05:17 AM
Optical Limits JOE65 Industrial Hobbies (Support forum) 1 03-21-2006 10:06 PM
limits jc286006 TurboCNC 2 09-08-2005 05:05 PM
