Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 06-11-2009, 11:48 PM
ruawake is on a distinguished road
IH versus Mikini Mechatronics 1610L
Wonder what anyone thinks of the Mikini.......3hp?
Old 06-12-2009, 11:06 AM
Runner4404spd is on a distinguished road
i think the work envelope is kind of limited for what you get. the IH has full 30" of travel in the x and up to 13 in the Y. i can fit 3 6" vises on my ih mill and can get to each of them with plenty of room. i can't really tell if the complete mikini is running on mach 3 or their stand alone controller?
Old 06-12-2009, 12:20 PM
EvanVH is on a distinguished road
No dove tail ways ????? No ways period???
If I read the web site correctly they are using linear guides. I would worry about the longevity, rigidity and accuracy. (when you are pushing the machine hard)
Evan
Old 06-12-2009, 12:42 PM
That is a good point, about the ways.
ruawake
Old 06-15-2009, 03:06 PM
deon's Avatar
deon is on a distinguished road
Hi
"longevity, rigidity and accuracy"?????? Bigger mills like Haas etc. have them.
What seems to be the problem , if you stick to a the work machine scale relation then I cant see the problem.
It's not a good idea to break down a other manuf. just because you have a IH machine.
Just my two cents.
Old 06-15-2009, 11:19 PM
oltimer is on a distinguished road
deon
nobody is cutting down anything. just an opinion on an IH forum.
oltimer
Old 06-16-2009, 11:31 AM
Originally Posted by deon View Post
Hi
Just my two cents.
Hey deon
After doing some research I was off base with that comment. Sorry Can you separate the mill from the stand. The reason that I ask is the stand is cast (?) and the rep from Mikini said "the stand and mill don't separate". There web site said the mill weighs 2000 lbs with the stand. If the stand is cast it must be pretty heavy. I would like to know how much the mill weights with out the stand.
Evan
Old 06-16-2009, 11:39 AM
Evan,
your point of longevity is valid. in the cnc world hass machines are considered disposable, after a while it actually becomes cheaper to buy a new one vs repair the one you have. cast ways will definitely last longer than the linear ways when under alot of load. i personally don't know what the load rating is on the mikini ways but on my ih i can machine stainless steel with no problems, on the cast iron ways. also i upgrade my ih with 3hp 3450 rom motor.
granted i don't have quite the upper end rpm of the mikini but on harder metals you don't need the upper rpm anyway. the ih will definitely be slower than a mikini on plastics due to the slow spindle but the trade off is versatility and the ability to cut harder metals.
Old 06-16-2009, 12:49 PM
Originally Posted by Runner4404spd View Post
Evan,
Hey thanks for the info. It is very interesting. You made a conversion plate to convert the metric spindle motor to a standard spindle motor on a IH mill. Did you ever make a drawing for it ? Maybe a dxf file If so I would love to have a copy. If not no big deal. Thanks for the info on linear ways.
Evan
Old 06-16-2009, 05:31 PM
philbur is on a distinguished road
I think if you work an IH as hard as an average Haas you will find it is also disposable, much sooner.
It seems the Mikini, with its C3 screws and linear ways will have much higher precision/repeatability than either the IH or Tormach. The down side is that it is a lighter weight machine (minus the stand) with a smaller envelope. So it's horse for courses, again.
Providing the service is there I think it looks like a great piece of kit.
Phil
Evan,
  #11   Ban this user!
Old 06-19-2009, 09:49 AM
Just a bit of info that a beginner like me is still trying to understand. When I spoke to the Mikini, He said that they built the machines a single unifiedpiece(built like a Haas), with a lower casting and an upper casting. A machine that is built all the way to the ground. I am looking forward to hearing from a new owner, and for the new videos.
  #12   Ban this user!
Old 06-19-2009, 01:48 PM
Kipper's Avatar
Kipper is on a distinguished road
Evan
I bet he never gets back to you.... Attached is a version another person made.
On topic....I'll bet the Mikini is a better machine....better spec and probably better made......should last a home user 20-30 years.....just think no gib strips to adjust....and a column all the way to the ground.....I'll take one.
Keith
2009 Mikini 1610L Forum - New control system MIKINI MECH General Metal Working Machines 4 06-14-2009 03:10 AM
MIKINI MECHATRONICS jalessi Product Announcements & Manufacturer News 1 03-27-2009 05:58 AM
Just IN- MIKINI MECHATRONICS - NEW CNC MACHINING CENTERS 16"x10"x16" 2000 lbs Linear Rail MIKINI MECH Product Announcements & Manufacturer News 23 02-25-2009 04:49 PM
Ease of use.. GibbsCAM versus Mastercam versus BobCADCAM, etc.? squale General CAM Discussion 4 11-10-2008 05:41 PM
Mister versus flood versus ??? coolant system split63 Bridgeport and Hardinge Mills 14 10-02-2006 06:18 AM
