Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 06-07-2009, 03:32 PM
Dreadnought is on a distinguished road
What is 'XY Table Extensions'?
Old 06-07-2009, 03:52 PM
Runner4404spd is on a distinguished road
the xy table extensions are two aluminum blocks that space out the drive mechanisms of the x and y axis to try and retain the full travel of the mill or increase it slightly. i have both on mine and the added space has been a benefit in larger applications.
Old 06-07-2009, 05:12 PM
Thanks,Runner.
I've read your threads and get lots of information.
I'm looking for a milling machine with bigger work envelope for home workshop.
Knee mill is too heavy.
Maybe ZAY series is a better choice.
Old 06-07-2009, 07:25 PM
altaic is on a distinguished road
Are those only applicable to the IH CNC machine/kit?
Old 06-08-2009, 06:57 AM
i believe the IH kit is now only sold for IH mills so you couldn't get the extensions anyway for the ZAY series.
Old 06-08-2009, 10:27 AM
I have an IH manual mill. I'm just trying to imagine those blocks-- are they to move the IH CNC kit's axis motor/belt assembly because the assembly's flange interferes with the table travel beyond when the saddle is flush with either the table or base?
Old 06-08-2009, 01:54 PM
Yes, I noticed that.
In fact I'm in China, so I can't get them both, IH mill/kit.
I shall get a ZAY mill with 1000mm×240mm table.
And make my own parts for CNC conversion.
I've already found servos, drives, Turcite, etc.
It will be a great machine for my hobby when the job done, I suppose.
Now I have SIEG C3 & X2, lovely little machines but too small.
The problem is:
What Continuous Stall Torque and Peak Torque the servos should have?
Old 06-08-2009, 02:47 PM
When the table end is aligned to the saddle side, it's not the max travel.
The table can go further until the handwheel nearly contact the saddle.
So the assembly's flange should be spaced out to achieve the max travel.
Just like Runner said.
Old 06-08-2009, 03:22 PM
dreadnought, the size of servo is always the question for these machines. its a delicate balance of cost vs perforamnce. you don't want to oversize but you definitely don't want to undersize. ultimately in order to get good results on these machines you need havea fair amount of torque so you can get all the gibbs nice and snug.
New Machine Build- File extensions on oi-mc jamesweed Fanuc 2 07-17-2008 11:36 AM
Any body recognize these file extensions (types)? 68rustang General CAM Discussion 6 02-04-2008 06:43 PM
adding file extensions GRANDPA NCPlot G-Code editor / backplotter 2 03-15-2007 09:14 PM
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 01:21 PM
File Extensions in PFE E-Stop Mastercam 0 06-25-2004 07:53 AM
