Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 05-31-2009, 01:27 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Using a DRO to map your ballscrews
I have a nice Fagor DRO that I bought for a lathe that I wanted to mount on my mill in order to map my ballscrews. It is supposed to be accurate to 0.0002", so it should be a nice reference for calibrating this mill.
First job was to make brackets. Very easy with the Mach3 wizards, especially the Newfangled Wizard. Here is the reader head bracket for the scale on the X-axis:
The reader head mounts where the home/limit switch goes. The DRO is only temporary and I didn't want to make any new holes in my mill! Note how the bracket protects the head a bit...
Each end of the scale is held by a little L-shaped bracket. You need to be able to tram the DRO scale in so it is level and square with the table...
And here is the control panel for the DRO...
Old 05-31-2009, 01:31 AM
The bracket was very easy to make using the CNC Wizards in Mach3, and especially the Newfangled Wizard. Here are some pix of the construction of the reader head bracket:
Love my 5/8" Helimill. Those APKT inserts cut through aluminum like butter!
I thought I'd map my X ballscrew just to check its accuracy with the DRO. Here is what I found with a series of half inch jogs:
The left axis shows the actual move of each commanded 0.5000" move as measured by the DRO. If the ballscrew were perfectly accurate, the graph would be a straight line centered on 0.5000".
You can see the righthand 40% of the ballscrew is qutie a bit more accurate than the left, although the first maybe 10% on the left is quite good too. Nevertheless, the whole screw moves to well under a thousandth of accuracy. You can also see that the errors are not cumulative, but are more periodic. The total error in 24 inches of motion was 5.6 thousandths and the screws are advertised as having less than 3 thou per 12", so this screw is within spec.
Mach3 has the ability to take such a map and use it to offset the errors, but I haven't played with that yet.
Cheers,
BW
Old 05-31-2009, 05:01 AM
philbur is on a distinguished road
Hi Bob,
Did you do any repeatability tests (and reverse). Might what you see be "stick - slip" and nothing to do with ballscrew accuracy.
Phil
Old 05-31-2009, 08:15 AM
LUCKY13 is on a distinguished road
Originally Posted by philbur View Post
Hi Bob,
Phil
Thats a very good possibility. It would seem that one complete move would be better for testing.
Never the less thats pretty cool how we can make a graph like this for Mach of we have the right tools.
Jess
Old 05-31-2009, 11:07 AM
rowbare is on a distinguished road
From the way your measurements are skewed, it looks like you need to adjust your steps per inch slightly too. Of course we are only talking about 2.5 tenths here...
Old 05-31-2009, 12:24 PM
I remapped the first 30% or so and it was repeatable within a tenth or so. The DRO is only supposed to be good for 2 tenths, so I believe these figures are within the limits of experimental accuracy.
I also calibrated steps per inch before beginning the mapping using the DRO.
It is likely that there are other factors beyond the ballscrew that contribute to the errors. I know, for example, that while I have very minimal backlash, it differs quite a lot in one direction versus the other. That asymmetrical backlash sounds like a mechanical effect of some kind (gibb wedges more in one direction perhaps?). However, these measurements were all made with one direction of movement and after an initial move of 1" to clear the backlash.
That 30% remap was by accident. I jogged the axis the wrong way through a mistyped MDI command, but I did get to see the behavior.
If anyone were going to spend much time tuning up CNC's, and you didn't have the bucks for the laser systems and ballbars, an accurate DRO is a very handy gizmo. It only took a couple of hours to fit it up the X scale from scratch.
The one thing I would do differently if buying a DRO specifically for this purpose would be to interface the scales directly to Mach3. These glass scales have standard encoder connections on them I noticed. It would be rather cool to have real glass scales running with Mach all the time to confirm what's going on.
Cheers,
BW
Old 05-31-2009, 01:28 PM
Whats really odd about the graph is how it alternates from being short, then over shooting every other turn ( did I say that right). Its almost like the screw has a bow in it. Also the far ends giving a better reading would support the thoughts of the screw having a bow (bend) in it.
I would like to see more test like this Bob, you might just be on to something here that will help us get our machines to perform more accuratly. It would be nice if Mach3 could take this info and ajust things until they where dead on.
Jess
Old 05-31-2009, 01:40 PM
Jess
Jess, you are a clever man with this suggestion of a bow!
Why do I say that?
Well consider this: the noisy end of the screw is the unsupported end. The more accurate end is supported by the bearing block.
Hmmmm. Sure would be fascinating to add a floating deep groove at the far end and rerun the test, wouldn't it?
These test are done at the 120 IPM rapids rate too. Would also be interesting to check it with a much slower jog rate.
So many projects, so little time!
Cheers,
BW
Old 08-26-2009, 10:12 AM
NEATman is on a distinguished road
BW-
Great idea to map the screws. I think I may rig up a DRO on my mill and check it.
I also agree with Jess regarding the bow.
What is the lead of the ballscrews? I'll bet that it is 0.2".
If it is, have you tried re-running this test the exact same way with an incremental move of 0.2" or 0.4"? I would guess that the graph would look completely different, as some of the error you are seeing alternate up and down is most likely caused by the ball nut not being mounted perfectly square to it's axis, and part of the reason you are seeing the up-and-down is that the 1/2" move is 2.5 rotations of the screw.
If you want to get really crazy about aligning the ballnut, you could take the same approach as the one shown here:
http://www.universal-thread.com/lead2.htm
Take a very close look at item #3. It is a tube that has three pairs of flexures 90° apart to allow the nut to self-align. It is a very elegant solution for a complex problem. If you use this approach, be sure to only clamp on the extreme end of the tube, as shown here:
http://www.universal-thread.com/mounting.htm
I have an idea for a inexpensive "Ball-Bar" that I need to make some year... I'l get to it eventually. In the mean time, I should try out your method. :-)
Keith
Old 08-26-2009, 02:16 PM
Mike Nash is on a distinguished road
I know it's an older post, but I just saw it. I'm betting you would find your ballscrew pulley is not running perfectly concentric. I saw this on my mini-mill. It's alternating sides at 0.5" moves.
  #11   Ban this user!
Old 08-27-2009, 08:15 PM
Interesting speculations.
I quit fooling with it based on where I've gotten to with accuracy. I'm better than 0.001" at this stage, and I have to go fix a lot of stuff to get rid of all the weak links of the chain and do better.
Cheers,
BW
Problem- VF-2 SS Ballscrews JoBwan Haas Mills 2 06-10-2008 06:55 AM
X2 Ballscrews ??s maxboostbusa Benchtop Machines 5 12-05-2007 08:38 AM
Used ballscrews quant Linear and Rotary Motion 6 06-23-2007 11:20 AM
How Bad is it Without Ballscrews? wallyblackburn Bridgeport and Hardinge Mills 16 01-17-2006 03:30 PM
Ballscrews on E Bay mxtras Linear and Rotary Motion 0 09-07-2005 04:50 PM
