Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 04-27-2009, 12:29 AM
Rich05 is on a distinguished road
Auto tool changer ?
Has anyone put an automatic tool changer on thier IH? would like to see pictures if so thanks!
Old 04-27-2009, 12:59 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Rich,
See the video below for a simple solution for smaller tooling.
It uses the High Tech Systems Rapid Changer.
http://www.hightechsystemsllc.com/pt_rapid_changer.html
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 04-29-2009, 01:50 AM
very cool i wonder how this would work on ih table
Old 04-30-2009, 10:36 AM
Cruiser is on a distinguished road
Without a swing in / out design this would take away from the work envelope considerably. altho, just using the tool system by itself would be very convenient, up to 1/2" tool. And changing by hand would be quite fast.
Don
IH v-3 early model owner
Old 04-30-2009, 12:17 PM
EvanVH is on a distinguished road
This is a nice tool changer all home built. Nice job Hoss!!
http://www.hossmachine.info/forum/ya...l-Changer.aspx
Evan
Old 05-01-2009, 08:25 PM
pjensen is on a distinguished road
I own one of the high-tech systems quick changers, and have used it on my Taig. They are nicely made, but not what I would call "heavy duty."
It is not able to hold the tool without slipping under even fairly light loads. For example, milling a 0.1 slot through a cast aluminum box lid with an 1/8" endmill causes some slipping. The IH mill should be able to hold the spindle more rigidly than the Taig manages to, so the chatter I get should be reduced or eliminated, but the tool slipping would be a problem.
These tool changers would work fine for PCB milling or engraving type applications, milling plastic, and _very_ light aluminum milling, but don't expect to take that 1/2" cutter and hog through steel with it. On the other hand, this system does make tool changes a snap.
If anybody wants one, mine is up for sale
Cheers,
-Peter
Old 05-02-2009, 12:55 AM
There are other quick change tool holders that are available for bridgport type mills that would not slip and would be good for hogging and finishing, but they are quite spendy as I recall, plus I haven't seen them in a while.
Don
Old 10-17-2011, 03:39 PM
philbur is on a distinguished road
You could fit one of these:
Automatic Tool Changer | Tormach LLC | We provide personal small CNC machines, CNC tooling, and many more CNC items
Phil
Old 10-17-2011, 11:08 PM
jetflatline is on a distinguished road
I gotta say, I am tempted to try.
Old 10-18-2011, 03:31 PM
DarkStarMedia is on a distinguished road
Eventually I want to make an umbrella style (when I get a mil setup) but I think using anything other than NT30 with the drive dogs is asking for trouble...
Based on much of what I read it should not be too hard to make an ATC... plenty of plans/info out there...
But... I am far from and expert.
Richard
How fast is this? jmytyk DIY-CNC Router Table Machines 8 02-07-2009 06:41 AM
Need Help!- Need help fast F3RR3T General Metal Working Machines 1 02-02-2009 11:03 PM
Routing Aluminum as fast as I can? Imperium General Material Machining Solutions 5 10-17-2007 09:11 AM
How Fast is too fast? lgalla Linear and Rotary Motion 2 04-29-2007 08:38 AM
RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED - JavaDog Employment Opportunity 6 11-17-2005 03:25 PM
