Originally Posted by
HimyKabibble
I fail to see how damping or gain can cause flat spots in your cuts. The Geckos will *always* drive to the commanded position, it's just a question of how hard they'll "push" to get there, and and hwo they'l react to counter-forces. You want gain as high as you can get it, without instability. If gain is too high, you'll have excessive noise, and perhaps over-shoot. Too much or too little damping will change how it approaches final position, and it's ability to hold that position.
I got all three of mine setup in about 10 minutes, entirely by ear. Start with both gain and damping at about 10 o'clock. Jog the axis back an forth at rapid speeds. Increase both gain an damping, and try again. At some point, you'll find the motors start growling when stopped, but still move nicely. At that point you're close on gain. When set properly, Geckos *will* growl periodically when stopped. About once every second or two seems to be the ideal setting. Now start doing some really heavy cuts, and very fast rapids, and you may find you sometimes lose position. If so, then reduce the damping, and try again. The best setting will have gain as high as possible (to make the axis really "stiff", and damping as low as possible (to make it very responsive). If the gain is too low, the axis will be too quiet when stopped, and will be prone to position loss. If too high, it will be maiking constant noise when stopped (and the motors will get hot). If the damping is too low, you'll get over-shoot, oscillation, or faulting when accelerating rapidly. If too high, response will be slow, and you won't be able to accelerate rapidly without faulting.
Doing this, I have my knee mill running almost 400 IPM rapids, and all three axes are nearly unstoppable - they'l break tools without losing position. The tuning is NOT difficult, and does not require an oscilloscope, just a good ear and some common sense. Remember - get gain as high as you can, then tune damping to get good stability.
Regards,
Ray L.
