Results 1 to 4 of 4
Thread: pulley ratios : motor to ballscrew
    Mar 2004
    DERBY LINE, VT, USA
    Hi, I purchased an IH mill from its previous owner a while ago and much of the hardware to convert it to cnc. I have been off on other things for a while but now want to get the conversion completed.
    Here is what I have:
    (1) Homeshopcnc 850 oz/in at 72 volts with 4200 rpm at constant voltage
    (2) 3/4 5TPI Rockford Ball screws
    (3) I have 72 volt power supply.
    I am trying to decide on the pulley ratios I should use for each axis. I am not sure how to make this decision. I know that 4200rpm and a ratio of 4:1 I should see ~~210 inch/minute linear motion with these balls crews. How can one analyze this situation.
    What rpm should I use for calculation and what linear speed should I be trying for? Should all the axis be the same? What other factors should I be considering?
    Thanks for your help.
    Kent
    Mar 2004
    DERBY LINE, VT, USA
    Is this question too dumb?
    Hi, Quite a few looks but no opinions.
    Is there too little information to give an intelligent reply or is the question to dumb to bother with? I am going with 4:1 as that seems to be what most people do but I thought I would try and make a decision based on theory.
    Just curious.
    Kent
    May 2007
    Not much time and I will not be back for a few days.
    I would aim for a resolution of around 0.0001 to 0.000025, but I would be using EMC and a torque or velocity mode servo system rather then a position mode (step/direction) that seems to be so popular. With EMC and torque/velocity mode control you do not have to make as much of a compomise between resolution and speed because you are not limited to the max step rate of the software .
    I would take a WAG and say a resolution less then 0.0001 is going to be pushing the limits of what your iron and parts can make use of.
    Jun 2005
    i would use a pulley ratio of about 4:1
  1. Alternate Motor Pulley?
    By giantcake in forum Shopmaster/Shoptask
    Last Post: 01-02-2008, 07:35 PM
  2. Lathemaster ZAY7045FG Pulley Ratios
    By bill south in forum Benchtop Machines
    Last Post: 11-07-2007, 01:13 PM
  3. timing pulley for for stepper motor
    By derkiow in forum Stepper Motors and Drives
    Last Post: 03-10-2007, 04:10 PM
  4. Motor pulley
    By JWOOD in forum Fadal
    Last Post: 03-31-2006, 04:45 PM
  5. How to removing a pulley from a motor ??
    By RotorRouter in forum General Electronics Discussion
    Last Post: 11-12-2005, 08:32 PM
