Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 09-07-2008, 02:15 AM
Capteod is on a distinguished road
Trouble tuning GECKO 320 Servo Drives
I am facing a new problem tuning a set of 4 320 gecko drives. I am using the following system:
Software: Mach3
computer: Dell c640 2.o GHZ INTEL PROCESSOR
1 mbyte ram
Interface; SoundLogic Combo Board, from Campbell Design
Servo:
Power Supply: 65 VDC 10Amp
x & y servos: 875 InOz
z servo 1125 In0z
My problem is that regardless of the settings of the three pots, I get faulting. I have reduced the speed, to 50 IPM and 15 sec acceleration. The Step and direction pulses are set at 5.
The machine is a Industrial Hobbies Square column Mill.
I set up mach3 with a kernal speed of 25KHz. I can function the jog but it will fault out every time.
Any help will be appreciated. We scoped GECKO output and cannot get the dampening correct. The motors seem to be tuned correctly, they will hum when you attempt to over-power the servo.
Old 09-08-2008, 01:56 PM
IHCNC is on a distinguished road
Hi Capteod;
Email us with your particulars ( servos, system ETC.) plus a phone # and we will help you out.
IHCNC
Gene & Tommy
Need Help!- Tuning Gecko 320 servo driver Capteod Machine Problems, Solutions , Wireless DNC, serial port 3 09-12-2008 11:49 PM
Is Gecko 320 tuning supply voltage dependant? digits Gecko Drives 0 06-19-2007 06:59 AM
Trouble tuning drive mecheng10 Servo Drives 2 04-11-2006 07:28 PM
Oscilloscope settings for G320 servo tuning + trouble giorgiocnc Gecko Drives 4 12-10-2005 04:44 PM
problems with tuning of Rutex drives FrankdB Servo Drives 2 06-21-2004 03:16 AM
