Hi All,
I didn't do a backup like a dummy and my HD died. My machine was a turnkey machine built by Aaron. By chance, does anyone know the pin configuration or have a Mach3 file I can use?
Thanks for any help,
Craig
Hi All,
Craig
Bummer!
The xml file from my mach3 is attached but has a dxf file extension. Xml files are not on the list of approved attachments, so save it and rename the file extension.
My file is from a DIY IH mill and will not have all of the settings that IH puts in for your VFD etc.
You can give Gene or Tommy a call and they can email you the file that matches your mill.
Bohica
Noncarborundum Illigitimus
Hi Craig;
Called you today about your problem. It's easy to fix, call us and we will set you up.
IHCNC
Gene & Tommy
