Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 04-30-2008, 09:57 PM
richardsohn is on a distinguished road
IH DIY CNC conversion
I have a new manual IH and am working on the CNC conversion. The stepper controller is done, and now working on the mechanics.
My only still open item, is the installation of ball screw nuts, more direct, the attachment to the Y-table. Is there a design someone has done before? I have no information on the factory version.
Any ideas are welcome.
Old 04-30-2008, 10:15 PM
Runner4404spd is on a distinguished road
when i converted my round column mill, i basically just duplicated the factory nut except added a provision for the ballnut to screw into instead of the factory acme screw. worked like a charm. if you use a single center bolt it would make alignment a breeze but may not be ridgid enough for a full cnc. if your going to add bolts add a flange and drill the underside of the y axis cross slide.
Old 05-07-2008, 12:02 AM
richlandrick is on a distinguished road
I am also staring my own cnc conversion of a new IH mill. It's still sitting on the original pallet in my garage. This will be my forth conversion. the previous were mini-mill using sterlingsteel plans, a mini lathe using sterlingsteel plans, a Sieg C-6 lathe from Grizzly using my own design (similar to the sterling steel design). I also converted the mini-mill Y axis direct drive to a reduction belt drive. That design is remarkably similar to the fignoogle mini-mill Y-axis drive in appareance.
The IH Mill Y-axis would is remarkably similar to teh mini-mill Y-axis, so i would think a similar set-up would work. That's what I have planned anyway.
Now a question. When changing a collet or removing the R-8 3/4" chuck, how do you keep the spindle from turning while loosening the drawbar?
Rick (richlandrick)
Old 05-07-2008, 01:32 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Rick (richlandrick)
Ya'll take a look at the CNC installation instructions on the IH site. It makes it pretty darned clear.
RE keeping the spindle from turning, two options:
1. You can buy a wrench to fit the splines very cheaply off eBay, or you can make one with your CNC.
2. I built a powered drawbar out of an impact wrench. The impact wrench has so far never needed to keep the spindle from turning. It happily hammers things loose with the impacts.
Cheers,
BW
Old 05-08-2008, 06:03 PM
pete from TN's Avatar
pete from TN is on a distinguished road
On my Lathemaster.....
On my Lathemaster mill I usually just switch to the lowest gear and the torque needed to turn the spindle in low is pretty high and I just give the wrench a quick turn and after almost six years of doing it this way I have not had a problem with a tool turning in the collet. Altho I like the idea of a power drawbar like Bob mentioned. Once mine is cnc I will probably make one of those. Simple design and I am not sure it is even necessary to have the pneumatics. You have to manually insert the tool anyway so just pushing down on the impact unit while holding the collet to ensure it does not fall out would be no problem. Pneumatics are cool tho....peace...
Pete Matos
Matospeter@charter.net
865-363-9218
Old 05-08-2008, 09:32 PM
Thanks guys. It niether of those ideas gears or wrenching teh spindle occured to me. I assumed it would be like the mini-mill. A bar or something would slide into a hole.
The IH install instructions are helpful.
What's that standard ballscrew diameter for an IH?
I wa think 3/4" and would like to use preloaded ballnuts. Any fantastic sources out there?
Old 05-09-2008, 03:28 PM
Bird_E is on a distinguished road
Smile Check out my site for idea's
I'm converting a Lathemaster RF45, I'm mounting the Yaxis from the back of the mill. My site has some detail of this:
http://www.rlberg.com/
Old 05-10-2008, 07:34 PM
Yeah man and we need an update!!!
Looking forward to the next installment of the RF45 Lathemaster build you are doing. How's it going!! peace...
Pete Matos
865-363-9218
Old 05-20-2008, 09:04 PM
Update DIY IH conversion
I am expecting some ball screws with bearings and stuff from e-bay. Hope there is some useful. The controller is complete and working after I had to send a new Gecko back because it did not work. The problem was apparently found and I got a replacement.
I used the A axis to drive my turntable the other day, with an MPG. Everything seems to be working as planed.
Finally looked at the factory installation. It answered my questions.
Thanks for pointing me to it.
rs 232 conversion profhinsley General Electronics Discussion 5 02-06-2008 11:47 AM
VFD conversion drwc Phase Converters and VFD 5 05-15-2007 09:07 PM
The best conversion kit for X3 triump Syil Products 23 11-11-2006 06:59 AM
a conversion Kit for CNC US-GUN'S Benchtop Machines 5 08-10-2006 10:23 AM
conversion ? kenlambert BobCad-Cam 2 03-20-2005 12:26 PM
