Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 04-29-2008, 06:03 PM
Rich05 is on a distinguished road
Another Enclosure : )
7' x 3.5'
Door slides straight up.
Coolant collects in center, mill will be lifted 1" off the pan to get out of the fluid.
Plastic is just light weight plexiglass
The door will be on a track
The pan under the mill I plan on using 1/16 aluminum.
Any suggestions greatly appreciated, I saw the other enclosure thread gots some ideas from it.
I am planning on upgrading to the 3hp motor. I want to get the max speed possible should I be shooting for 2000 gallon per minute pump?? Any advise appreciated.
I was looking around Enco did not see any high output flood kits, how much should a good kit go for any links sources thanks
Old 04-30-2008, 05:13 PM
dnelso is on a distinguished road
Pump
Here is a link to the pump i use on my mill.
http://www.lowes.com/lowes/lkn?actio...525&lpage=none
Its 525 gph. I use 2 water ports at the same time and the pump has plenty of flow. If your pump is to big you can empty your reservoir before it has time to filter back. I use a 15 gallon container for the coolant.
Dave
Old 04-30-2008, 07:46 PM
How high does it need to be??
Modified
10' x 4' aluminum plate 1/8" thick $411 + 4 cutting setups $15 + $8 for cuts = $512 Industrial metal supply.
some modifactions made the box a bit longer on one side to accomidate the servo on the mill table, reduced size a bit
7' x 40" x 5.75" high on the pan 40" high (will that be hight enough?) I need to keep the flood in the box!
thanks for link to pump is that enough coolant? I was told 1500-2000 gal per hour. how about hoses filters, etc how about even chip convayer?
Old 04-30-2008, 09:41 PM
enclosure
Rich05
My enclosure is very similar to yours.I have posted thes pics before. I have one center drain and in the channels i have screen rolled and rtv in place. i started with a 750gph pump and after about an hour of running i could empty the 15 gallon reservoir before it could drain back. If i was doing it again i would have 3 drains and then could run a bigger pump. The screens do a good job of getting the big chips but the smaller ones go to the bottom of the tank. I clean the tank about every 3 months. The pump has a filter on it and is mounted about 4inch up from bottom of the tank. Also a bubbler from a fish tank is needed to keep the fluid from getting nasty.
ID:	58769   Click image for larger version
Old 04-30-2008, 09:52 PM
very nice
I saw your pictures before very nice! How big is your enclosure on the inside around the mill 4x8?
What GPH pump would you recomend do you have any links?
I looked Mcmaster there flood pumps max out around 600GPH. Not sure where to start with pumps, filters and such.
Definitly want to get allot of coolant on the part.
Old 05-18-2008, 11:53 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
wow nice set-up.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 05-20-2008, 01:36 PM
Dolphin USA's Avatar
Dolphin USA is on a distinguished road
I agree. Looks nice.
Dolphin CAD/CAM Support
Download a free trial at
http://www.dolphincadcamusa.com
Old 05-24-2008, 05:52 PM
skullworks is on a distinguished road
Draw bar access?
Rich - You may want to look at where the head will be during tool changes an be sure your vertical door won't hinder access to the drawbar.
Then again you could try to rig a power drawbar.
Old 05-29-2008, 03:29 PM
DonFrambach is on a distinguished road
Probably a really dumb question
The central drain design looks very tidy. But I have a concern. Do you have problems reaching in under the mill to clear swarf?
Old 06-01-2008, 06:29 PM
georgebarr is on a distinguished road
I am considering building a similar bench and enclosure for my IH mill. So that I can start creating the CAD file, I need some measurements, anyone? I need to know the total maximum height of the mill when the Z axis is moved all the way up away from the X-axis. This will tell me the max height of the enclosure. Also, what is the width and length where the bolts secure the bed of the mill to the bench (measurements between the bolts)?
The main purpose of this enclosure is to provide fluid coolant protection as well as sound absorption.
Can some provide these dimensions? Oh, my IH CNC mill will ship to me in 4 weeks and this is why I am asking you folks.
Thanks,
  #11   Ban this user!
Old 06-12-2008, 06:39 PM
Done finally!
Sure got some TIG welding practice! The pump in is 25 gallon container about 1000 GPH, 9GPM +/-, 5 x 3" drain tubes keep coolant moving. I have a bubbler in the tank and a oil skimmer belt on the way.
How much faster can I go now???
  #12   Ban this user!
Old 06-12-2008, 07:11 PM
pete from TN's Avatar
pete from TN is on a distinguished road
Rich......
Damn that is looking good!! You must be pretty happy now that you have flood coolant especially at that velocity. I am getting started on my conversion right now and just placed an order for my ballscrews and nuts and got my gecko g320's on the way. Also got some motors here now. Trying to figure out the setup I am gonna use for the belt drive and how I am gonna mount my encoders on the screws the way I want to. Congrats on a nice setup that I hope to be there someday soon. It seems like these machines are pretty well regarded by their owners for them to go thru all the trouble of building sweet enclosures and everything. Must be more than just a toy I guess huh!! Peace man....
Pete Matos
865-363-9218
What to use for an enclosure? Tim Wiltse Xylotex 8 10-03-2008 02:36 AM
tl 1 enclosure fourperf Haas Lathes 3 02-25-2008 04:56 AM
My new enclosure David Da Costa Commercial CNC Wood Routers 3 10-28-2006 12:03 PM
New All In One Enclosure mlaws1172 General Electronics Discussion 5 10-20-2006 07:26 PM
My Enclosure please take a look. Oldmanandhistoy General Electronics Discussion 36 03-03-2006 07:48 AM
