Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 09-17-2007, 10:51 AM
Runner4404spd is on a distinguished road
IH way covers
anyone find something better than the accordian bellow that cover the ways? mine are alsways falling appart and i'm tired of fixing them. also they get clogged with chips alot and get thrown off track. should i just run without them?
Old 09-17-2007, 12:33 PM
Cruiser is on a distinguished road
I depend on coolant flood to keep ways washed off. No matter what you do some of the fine swarf will find its way into where you don't want it. but it mostly depends on what you cut and feed rates. cast iron is bigest offender for swarf. I'd really like something to protect my ballnuts tho, when i had to open my z ballnut, i found some fine in there ! we do need to come up with something that works ! ON this i agree, but the space at the limits of travel makes it really difficult to design something that will function. What we need now i guess is a real brain storm !
Don
IH v-3 early model owner
Old 09-17-2007, 04:36 PM
i guess the real issues comes when using the mill manually.
Old 09-18-2007, 03:54 PM
IHCNC is on a distinguished road
Column way cover
What we use on our Turnkey CNC Mills is a 7"x16" piece of neoprene/vinyl/buna-n rubber sheeting. McMaster #85175k77. Make a angle shape bracket to fit over the dovetail (use the accordion as a model). Rivet the material to the bracket and then use the original top screw holes to mount it. Works great.
IHCNC
Gene & Tommy
Old 09-18-2007, 11:05 PM
thanks guys, thats along the lines of what i was thinking of adding, but it didn't seem sophisticated enough. i can see that working on the vertical ways but what about the horizontal ways behind the table? maybe its not worth covering?
Old 09-19-2007, 01:18 AM
Runner440
Use the way cover that comes with the mill. It is good rubber and is easy to clean. Same goes for the front, but it is made of steel.
IHCNC
Gene & Tommy
Old 09-19-2007, 11:48 AM
the rear rubber has cracked in multiple places and i need to replace it. i do alot of work with my IH mill and it does everything i need.
Old 09-19-2007, 02:35 PM
Runner440
The McMaster-Carr #85175k83 at 3/16 will work, just make two 1/8" to 3/16" x1" aluminum strips to mount it to the column and slide.
IHCNC
Gene & Tommy
Way covers !! Super x3, where and $ ? scyan Syil Products 16 10-05-2007 11:51 PM
Way Covers For SX3 Old Megawatts Syil Products 9 06-15-2007 11:03 AM
shoptask way covers kb7vms Shopmaster/Shoptask 4 02-24-2007 05:41 PM
BP Series II CNC way covers unterhaus Bridgeport and Hardinge Mills 3 12-26-2006 09:09 AM
Way covers for Taig warpedmephisto Taig Mills & Lathes 5 06-19-2006 01:59 PM
