Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 09-16-2007, 12:49 AM
Shepard is on a distinguished road
Don't know what I broke on IH CNC
I was unravelling the wires from around my machine, IH CNC, and put the Y axis encoder wire on the X axis. The X ran away and hasn't worked since. The motor still spins, I swapped the geckos and it's still good, wiring and encoder seem fine. The motor won't even lock up. Powered up I can turn the axis by hand. It will make feeble, itermittant attempts to lock up and the gecko will fault out. I tweeked the gecko adjustments till I can see them with my eyes closed.
Any help is appreciated, Shepard
Old 09-16-2007, 04:03 AM
IHCNC is on a distinguished road
Call Me
Hi Shepard;
Call me tomorrow night (Sunday) about 9 pm EST and we'll go over what you did and see if we can fix your problem over the phone.
IHCNC
Gene & Tommy
Old 09-27-2007, 11:39 AM
Cruiser is on a distinguished road
I'll venture a bet that the axis bottomed out HARD and you smoked the motor ! ! I smoked mine by going through the limit switch then absent mindedly bumping the axis the wrong direction ! ouch !
Don
IH v-3 early model owner
Old 09-27-2007, 12:15 PM
You are exactly correct. I thought the motor was still good but was wrong. I came across a nema 34 servo for a song that only needed a couple flange holes to be opened up to bolt on to our IH bracket. I'm waiting for the timing pulley to get here and should be up and running.
she,s a broke eh corrie Machine Problems, Solutions , Wireless DNC, serial port 3 09-12-2007 05:08 PM
r-8 locating pin broke jarr88 Benchtop Machines 3 08-26-2007 07:32 PM
HL1 Counterbalance Spring Broke Geof Haas Lathes 2 07-26-2007 12:37 PM
I found a Sherline set and then broke it. Ubarch Benchtop Machines 2 10-29-2005 10:27 AM
Broke my Drill Press! JavaDog General Metalwork Discussion 4 09-01-2005 06:31 PM
