Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 08-14-2007, 02:30 PM
Bird_E is on a distinguished road
Linear Rails for the Z Axis
Has anyone tried to use Linear Rails for the Z-axis of an RF-45 clone machine and eliminate the Dovetail?
I would think this would make a much smoother Z-axis? Has anyone tried it or have any thoughts about this? I did see one post where someone is mounting the rails on the sides of the column in a seudo Slide/Dovetail combination.
Thanks!
Bob
Old 08-16-2007, 01:56 AM
SMW Precision is on a distinguished road
Thanks!
Bob
Bob, the IH System use a slide configuration if Gibs are correctly adjusted and lubricated there is little difference in resistance versus a ball bearing slide system. Several people have done this type of conversion with RF45 mills. I suggest you post the question in that forum and search through CNC zone posts for the topic.
Ken
Kenneth A. Emmert
SMW Precision LLC
Spokane, WA
866-533-9016 Toll Free
Old 08-18-2007, 10:46 AM
wildcat is on a distinguished road
You might check in the following thread...
http://www.cnczone.com/forums/showthread.php?t=35961
Old 08-18-2007, 10:24 PM
Cruiser is on a distinguished road
Bob
I'm the one that added slides rails to my "Z" axis. Reason was briefly that to draw my gear box up with the gib to pull the box slideway to the column slideway ended up with too tight of gib and binding. loosening gib allowed box to droop from slideway and we refer to this as cantelevering. I didn't get along with the gap at the top of the slideway so started figuring this system and it works good ! Now i have gib @ zero to control any possible rotational forces of gear box and the rails to pull the slideways together. All in all i feel that the sliding resistance is less by far than it was trying to adj it with gibs alone and keep in mind mine is the 10" square v3 model and the new 12" is supposed to be much stronger. your mill should be capable of carying rails like mine but the process of milling the colomn with a router on a bracket clamped to sadle got a bit hairy and not too pretty, but its functionality that is needed ! Figure on keeping the doves in use if you add rails and good luck !
Don
IH v-3 early model owner
Old 08-20-2007, 03:40 PM
Cruiser
I did see you posts on adding the slides to the sides of the column.
1. Do you even need the gib and dove tail now that you have the slides on the machine, and if so why?
2. do you think it would be possible to mill off the dovetails and mount the slides to the front of the column?
Thanks!
Bob
Old 08-20-2007, 04:12 PM
BOB,
Yes the gibs are needed, as the rails can't support the forces generated in all directions. The two together tho work to such a degree that I won't change it now, I like it !
You could mill off the doves and then re engeneer the slides, but rails such as mine may not be strong enough in the bearings after the mounting is disigned for carrying the heavy gear box. As stated above, the two work together and have solved the problems i had admirably. Cantelevering is abolutely NO MORE ! and i don't have a shaking gear box or trouble tramming in "Z" any more. the whole machine feels much more stable and no more sticksion since gibs are not near as tight as they once were.
Don
Old 08-27-2007, 12:14 PM
deon's Avatar
deon is on a distinguished road
Hi
I am in the process of installing rails to my Rf-45. The X and Y axis are done. Haven't gotten to the Z yet. Still busy mounting the ball-screws.
I do agree by setting the gibs you might come close to smooth movement and fair accuracy, but in the long run slides is almost everlasting on a hobby mill as the RF-45. That much cant be said of the quality of the castings of the RF-45 mills.
This is why I am taking the time and effort to strip down my brand new never used RF-45 mill to install linear slides and ball screws.
Cruiser has got me worried now about the rails on the Z not being capable of handling the forces. I will have to check this out very carefully.
Deon
Old 08-27-2007, 12:29 PM
Pictures of the Rail
Deon,
Can you post some pictures of your rails for X and Y or give a little more info!
THAT WOUDL BE GREAT TO SEE!
Thanks!
Bob
Old 08-27-2007, 01:06 PM
deon's Avatar
Hi Bob
OK. It's sleeping time in South Africa now.
I will take a few pics tomorrow and post it same time tomorrow.What I can say for now is, I used THK SR15 linear slides.
Had to cut some of the dove tails away but it looks good and works great.
I must say it is really heart breaking to cut up a brand new machine but I think in the end it will be worth it.
Talk to you again tomorrow.
Deon
Old 08-28-2007, 01:04 PM
deon's Avatar
Pics I promised
Hi Bob
Hope you can make sense of the pics. Any questions let me know.
Just for interest sake , The pic of the complete assembly you can see my sons hand.......It must have been standing at a slight angle he had to steady it other wise without the ball-screws attached it runs away by it self.
Movement is as light as a feather and very precise. All rails have been mounted on the original slide surfaces only pockets was cut to take the bearing blocks and part of the dove tails has been removed.
Deon
Name:	y-axis pockets.JPG‎
ID:	42771   Click image for larger version
Name:	y-axis assem.JPG‎
ID:	42772   Click image for larger version
Name:	x-axis poc+ballscrew.JPG‎
ID:	42773   Click image for larger version
Name:	x-axis linear.JPG‎
Name:	sadle on x-axis.JPG‎
ID:	42775   Click image for larger version
  #11   Ban this user!
Old 08-28-2007, 01:33 PM
Wow!
That looks pretty sweet!
Couple of questions:
What size rails are you using: 25mm, 15mm etc....
What kind of machine did you use to do all the machining work on the RF45?
Do you need to leave the overhang on the rails or will they be trimmed?
last questions, do you loose any travel doing this conversion!
NICE WORK!!!!!
Bob
  #12   Ban this user!
Old 08-28-2007, 01:53 PM
A couple more questions
What did you use for datum surfaces so that everything remains square?
Thanks again.... I'm drooling!
Bob
linear rails lgalla Linear and Rotary Motion 5 02-08-2008 04:35 PM
Need some Linear Rails for Z-Axis ViperTX Linear and Rotary Motion 3 09-20-2005 10:29 PM
Orientation for linear rails on X Axis Mr.Chips DIY-CNC Router Table Machines 8 12-18-2004 02:48 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
Linear Rails BeerFizz DIY-CNC Router Table Machines 2 11-14-2004 11:29 AM
