Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 06-18-2007, 04:47 AM
james12s is on a distinguished road
which model is this
which model is the mil in the attached pic and is it good for a cnc conversion
also anyone know the approx weight (kg please if pos) and value plus anything wlse about it
thanks
james
Old 06-18-2007, 06:40 AM
afmcorp is on a distinguished road
james
i do not see an attachment
Old 06-18-2007, 07:10 AM
oh soz ill sort it
Old 06-18-2007, 07:11 AM
here it is
Old 06-18-2007, 07:14 AM
rad45 is on a distinguished road
Can't find the photograph.
Hi People, Am sorry but I also cannot find the attachment to comment on it's provenence.
Perhaps you could check that you actually did attach it to your post and if so, maybe you could post a quick couple of lines on how to access it please.
With kind regards,
Russell Dunn
Perth
Western Australia
Old 06-18-2007, 07:15 AM
its attached in the post above yours
Old 06-18-2007, 07:21 AM
hdj80 is on a distinguished road
Looks like a ZAY 7035(??) type mill drill with a DRO on it. Hard to say but I would say it has a DC varispeed motor by the looks of the front controls on the head.
I know SFA about CNC'ing mills but should be the same as any of the other RF45 type mill drills.
Old 06-18-2007, 07:36 AM
oh thanks mate i thought it was but wanted to check
Old 06-18-2007, 05:20 PM
BTW I just had another look at the pic and thought there was something weird about the machine. The table is extremely small. Looks like it has been replaced or cut down. The table if standard should be @ 800mm wide by 230mm deep. It looks like it is only 500mm wide.
Old 06-19-2007, 11:42 AM
casy_ch is on a distinguished road
I do not think so. It is only an impression because of two vices on it. If you enlarge the pic in a Paint programm you will see that it is 800mm in length.
Jean-Claude
  #11   Ban this user!
Old 06-19-2007, 05:49 PM
Markus53 is on a distinguished road
Looks like a Chinese made Rong Fu clone
Hi James,
The machine looks like a ZX7045 or ZAY7045FG, both Rong Fu lookalikes. I have owned a CNC converted Rong Fu and worked with non-converted ZX7045.
I think they are suited for CNC conversion, and i know a guy thats sells a model very similar to the one in your picture very with ballscrews allready fitted for around 1600 UK pounds.
Greetz,
Markus
  #12   Ban this user!
Old 06-20-2007, 06:39 AM
leeschaumberg is on a distinguished road
Strange Mill
This section is for INDUSTRIAL HOBBIES MILLS. The mill pictured is NOT one of the two models of Industrial Hobbies Mills. They are the 10 which is the old one and the 12Z which is the new one. The table size in the picture looks very SMALL. Table size on the IH mill is 39.5 x 9.375 inches. In metric it is more than 1000 x 235 cm . Work envelope is 30 x 12 inches. Weight is 950 pounds or 430 KG. The head mounting on the current mill is round.
The more you know teaches you don't know alot
Calcomp model 30 lez Printing, Scanners, Vinyl cutting and Plotters 36 02-26-2012 12:31 PM
can anyone help with this model? wedgie OneCNC 1 06-13-2007 05:39 PM
3D Model to 2 1/2D? barkster General CAM Discussion 6 05-11-2007 11:51 AM
Need to do a 3d model of a horse. ynneb G-Code Programing 2 03-01-2005 11:57 AM
Looking for someone to do 3-d model seansear Employment Opportunity 5 08-13-2004 03:39 PM
