Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 06-16-2007, 02:42 AM
fcollebluegate is on a distinguished road
Check ZX7045 GearBox
hello,
i would like to check the gearbox (ball bearings and gears) on my milling machine because the head is very noisy.
someone have some pictures about how to dismantle the head ?
I'm sorry for my poor english.
Franck.
Old 06-16-2007, 12:28 PM
Mike Nash is on a distinguished road
Franck,
I think this may be what you want. But I still say they are all NOISY!
http://www.cnczone.com/forums/showthread.php?t=26850
Lots of pictures in Post 16.
Mike Nash
Old 06-19-2007, 02:46 AM
Many thanks for your answer.
Old 06-21-2007, 02:25 AM
SMW Precision is on a distinguished road
Originally Posted by Mike Nash View Post
Franck,
Mike Nash
Mike,
I think you would be amazed at how much quieter the newer 12 1/2 inch versus a 10 inch IH which is still better than an RF45 in noise production.
My observations from a bit of comparison testing noise was about 50% less on a 12 1/2 IH mill. Difference is from the quality of gear set.
Ken
Kenneth A. Emmert
SMW Precision LLC
Spokane, WA
866-533-9016 Toll Free
Old 06-21-2007, 12:02 PM
Originally Posted by SMW Precision View Post
Mike,
Hi Ken,
I got one of the last few clearance mills from Aaron. And while I can't compare it to any others, I still consider it to be quite loud. Especially at high speed. Quite a bit louder than my HF 12x36 gearhead lathe. But then again, it's been torn down since shortly after I got it, awaiting my lazy butt to CNC it. The ballscrews, nuts, bearings and old Yaskawa servos are in so now I guess I need to get moving.
Old 06-21-2007, 12:30 PM
tai42's Avatar
tai42 is on a distinguished road
My new IH mill seems considerably quieter than my Sieg X2 mill. I expected the IH would be much noiser. Of course, people have a different opinions of what loud is.
Old 08-29-2007, 09:54 AM
kevin mey is on a distinguished road
Greetings, on my machine which was noisy I found that all the key-ways were way over size allowing approximately 10 degrees of play in the drive gears.I ended up making new keys. Don't Know if this helps.
Regards,
Kevin.
South Africa
Old 08-31-2007, 02:34 AM
IHCNC is on a distinguished road
Mill Noise
Hi Tai42
You are correct about the quietness of the new IH Mills. This is something that our manufacturer and we at IH have been changing in the last three containers. Better ways and a close tolerance gear head, still with our hardened gears for high rpm use.
IHCNC
Gene & Tommy
ZX7045 (Enco) Oskar Industrial Hobbies (Support forum) 3 05-31-2007 10:23 AM
VF-9 Gearbox Pump Problem JoBwan Haas Mills 4 04-05-2007 04:02 PM
RF 45 gearbox problem need help please fc911c Benchtop Machines 2 01-12-2007 04:56 PM
MILL gearbox oil vs grease? Trebleplink Mechanical Calculations/Engineering Design 9 12-24-2006 10:25 PM
digital lathe gearbox? dberndt General Metal Working Machines 5 09-26-2005 12:41 PM
