| Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here. |
| Personally I would buy new to get the latest version with factory ground ways and the larger head mounting. The IH mills have gone thru much refinement and the current offering is worth every penny. Add to the fact that IH is fully prepared to crate and ship - vrs trying to arrange shipment for a used mill will be all sorts of fun. You will need to build a palletized crate, arrange for riggers (unless a forklift is available at each end) and a host of other small issues. In the long run buying used could cost as much as new. |
) Have fun!-Bob |
| If you have a fair amount of manual machining experiece with basic mechanical and electrical skills it is a great experience. That said if you are missing the manual machining I would buy the mill and operate in full manual mode for some period. Kit form needs machining experience to setup properly.
__________________ Ken Kenneth A. Emmert SMW Precision LLC Spokane, WA 866-533-9016 Toll Free |
#10
| If you have the money get the mill cnc'd by IH. I am having some troubles geting my Y-Axis working without binding. It seems to be an alignment issue. I have also spent many many hours troubleshooting the ballnut/screw disasembling/ reassmebling to clean it out. Seems my particular Aluminum ballscrew mount on the Y-axis produces small Al particles every time I install the ballnut on the mount. Problem is you never see this occur as the particles are inside the mount between the ballnut and the ballscrew wiper...many hours b4 I noticed this. Each time I installed the ballsrew/nut assembly there was binding due to particles. In the end I had to install the ball nut on the mount disassembled, then clean the shavings, and rebuild the ballnut (bearings and all) on the mill. No I'm fighting binding due to other issues....Time well wasted. So if you have the money get it cnc'd at IH. |
#11
Does anyone know the cost for installation of their kit? For a college student, I'd say I'm fairly adept at machining, but I'm not quite sure I feel up to doing it myself. And I'd rather start making chips! Can anyone tell me if a residential floor (off campus housing) can support one of these things? I figure the usual 2x12's 16" on center, 1/2" underlayment. I plan on laying down a couple sheets of 3/4" oak or hard maple cabinet grade plywood to spread out the weight. Is IH's claim that a single person can move this in pieces accurate? I'm sure I could manage getting it down stairs, but I'm not so sure about up stairs (possibly several flights). I'm a gymnast and work out regularly, but I'm still only 160lbs... What kind of backlash kind I expect with the rolled ballscrews? I really need .001" accuracy or better, and would consider the X3 with cncfusion's new ground ballscrew kit if the IH (or my machining skills) aren't up to it. Thanks, iamscottym |
#12
| Hmm... the cost of the installation is the sum of the price for the mill, the kit, the optional VFD, three phase motor, and of course all the tools you need/want. I will not comment on if your floor will support the weight... You are smart to spread the load.I'm not a big guy and was able to move the pieces around by hand. But I would not want to carry them up/down stairs through doors by myself. Get a strong buddy to help. When possible I used an engine hoist when assembling the kit. Good luck I was able to achieve the backlash target (.001) you have in the X and Y but not the Z when measured with a test indicator. Actual machining was a different matter but that was likely had more to do with my skill and tool deflection than backlash. Better than .001 is a different matter. |
| A 5-axis CNC machine including a rotary axis | synthetiklone | CNC Wood Router Project Log | 11 | 05-23-2012 09:31 PM |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| 4-axis, 3+2, or 4+ axis programming system? | roboticist | General CAM Discussion | 0 | 09-04-2006 01:02 PM |
| Options for 2 Axis Head (to make 5 axis) | drewgarth | DIY-CNC Router Table Machines | 6 | 07-12-2006 12:37 AM |
